ATX Power supply repair help
GASANT
Joined Apr 30, 2012
Hi Friends
Can you please help clarify my problem. I am really confused.
I am trying to fix my atx smps.
The problem or confusion. Measurements on primary side.( hot side)
1) I place black probe of multimeter to negative of bridge rectifier and red probe to positive of main electrolyte capacitor and get a reading of 300v which I am happy.
2) However when I place black probe of multimeter on negative of electrolyte cap and red probe on positive of cap I get a reading of 24 v. (Same cap as no 1)
Is this normal readings regarding atx smps.
Thank you
Gasant
Dodgydave
Joined Jun 22, 2012
11,307
No,you may be reading across a different capacitor in the circuit, most ATX psu's have a split capacitor setup they are in series across the supply, so they can be used as a voltage doubler when connected on low voltages, similar to this diagram.
http://www.pavouk.org/hw/en_atxps.html
