i have an 85 kawasaki klt160 three wheeler. my problem is the lighting. the lighting coil lost its resistance so it puts out full voltage. burning out the lights. its a simple set-up wiring wise. the repair manual says (ac lighting voltage/ 3000 r/min) 11.5 volts to im guessing 12 volts and the coil resistance is .8 - 1.5 Ω. thats all the book states. a new coil will cost $300 or more which i dont and wont spend. i want to put an inline resistor in the harness. is it possible to do and if so, what resistor should i use?
thanks, dave
ps, it puts out 30 to 40 volts right now
thanks, dave
