ATV Winch
Discussion in 'The Projects Forum' started by vinny8765, Sep 27, 2013.
  1. vinny8765
    May 28, 2012
    22
  2. #12
    Nov 30, 2010
    16,705
    7,354
    The float charger doesn't stand a chance of delivering 90 amps. Use a battery..or two.
  3. vinny8765
    May 28, 2012
    22
    I was wondering if I could use two car batteries in parallel in conjunction with the float charger. Not the float charger alone x)
  4. vinny8765
    May 28, 2012
    22
    Should I use 12gauge wire since it'll be hitting maybe 90amps?
  5. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    Ampacity of 12gauge is 20amps!
    Max.
  6. vinny8765
    May 28, 2012
    22
    Oh dear. What should I use then?
  7. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    As long as it is not continuous and only momentary for short periods you may get away with #6 or #8 at a push.
    Especially if it is a long run.
    A long run and high current you will get a large drop if too small Gauge.
    Max.
  8. vinny8765
    May 28, 2012
    22
    Well it says if you're pulling 1/2ton you're going to draw 40 amps I most likely will not be lifting that much weight. So I'm sure I could get away with it
  9. #12
    Nov 30, 2010
    16,705
    7,354
    8 gauge will do 40 amps all day, but 47.76 feet, round trip, will cost 10% of your voltage. Any serious distance will require larger wire.
    Even worse, when the voltage at the motor goes down, the motor will try to use more current, which causes more voltage loss. Vicious cycle. Be alert for the smell of burning plastic. If you're going to let your drunk uncle play with this, install a 40 amp circuit breaker.
  10. shortbus
    Sep 30, 2009
    4,096
    1,692
    Your missing a very important thing here. Winches, like the one your talking about are for PULLING, NEVER for LIFTING!!!. The cap letters are not for showing anger but to show emphasis. A winch like this is not equipped to hold loads, so should never be used to lift something. Be safe don't hurt yourself or someone else.
