Attenuation in notch filter
Discussion in 'The Projects Forum' started by Marie, Jan 8, 2008.
  1. Marie
    Nov 20, 2007
    24
    I'm currently working on the design of an active power filter and i've to use a notch filter to eliminate 50Hz component. I've managed to get a twin T notch circuit which in simulation is clearly eliminating the 50 Hz component. Unfortunately, there is an attenuation b/w the input and output voltage.
    I'ld like to know if it is the typical behaviour of a notch filter.
    I've attached a schematic as well as the graph of the input and output voltage.
    Thank you n Best wishes
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. JoeJester
    Apr 26, 2005
    3,393
    1,211
    I noticed your notch was designed to attenuate appoximately 50 Hz [ 49.798 Hz ] but your signal generator is set to 150 Hz ... or am I reading your schematc diagram incorrecly?
    The scope output should replicate the input, only much lower amplitude, at the frequency you are rejecting.
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    Yes. You can see the phase-shift caused because the input signal is 150Hz and the notch is tuned to 50Hz.
  5. Marie
    Nov 20, 2007
    24
    Thanks been there; indeed the pot has resolved my problem.
    About the 150Hz signal generator
    Sorry, i am new to forum and i can see that i'vent explain myself clear.
    Well in fact, i want to eliminate the 50Hz fundamental component and pass all the harmonics. This is why i set the generator to 150Hz to see if i could recover the harmonic signal without damping.
    Thanks a lot.
  6. JoeJester
    Apr 26, 2005
    3,393
    1,211
    Marie,
    Not a problem.
  7. Audioguru
    Dec 20, 2007
    9,411
    896
    You need to increase the Q of the filter so it rejects 50Hz but passes 100Hz and 150Hz without loss. The output voltage divider adjusts the Q.
