I have a suspect A to D chip, that samples about 5 different analogue voltage levels & converts them to digital (under the control of a Motorola DSP)
I'm an analogue man through & through...I've never had to troubleshoot AtoD (or any other digital) chips...I need a bit of help where to start!! (links, tips, books, general advice etc)
Tools wise, I have a 2 channel USB oscilloscope and a multimeter..but that's it!
Here's the actual chip...
http://focus.ti.com/lit/ds/symlink/tlv0838.pdf
(even though the datasheet shows that the IC has 8 analogue channels in, the circuit doesn't use them all).
And the circuit I'm working on is attached to this post
I've checked that VCC is there...it is.
I've checked for clocks - all present.
I've checked the DC levels on the on analogue inputs change when their associated pots are turned - they do.
I suspect this chip as being perhaps faulty, because no changes are heard from the mainboard's audio ouput when I move these associated pots (eg tone, volume etc) - this particular chip got very hot when a cable loom was connected to the mainboard erroneously....but it'd be nice to prove it.
Otherwise do folks just order a replacement & slap it in on the off chance it was the IC? (it's SMT, so this isn't a great option for me!)
