Atmel 89xxx Programmer troubles...
Discussion in 'Embedded Systems and Microcontrollers' started by doggiedoc, Feb 15, 2009.
  1. doggiedoc
    Dec 16, 2004
    51
    Hi all -
    A couple of years or so ago I built this kit (K123 v1.1) that I purchased from a local electronics shop. At the time I didn't have a Windows OS based PC to communicate with the programmer so I put it in a drawer until a couple of weeks ago. Now that I have a machine that will run Windows OS too, I have been trying to program some AT89c52 and AT89c4051 µC units that I purchased back then too.
    I am having troubles in several areas and have now gotten frustrated and am not sure where the "root" of the problem may be. I'll try to explain: I am compiling assembly with M-IDE Studio for MCS-51 to create the hex file. I think that is going ok. I am then uploading the file with hyperterminal (because the recommended term.exe won't run under XP) which seems to work on a fresh chip. If I try to program a chip again - it appears to erase ok, but "Blank Check" fails.
    I have not been successful in setting up a circuit to test the program either. I don't know if I am setting the circuit up wrong, or if the program isn't burned to the chip or if the hex file compile failed or what.
    I have searched diligently but I am unable to figure this one out. This is not a homework project or anything like that so no flames please. I do this to learn for "fun" LOL.
    The following is the code example I am trying to use:
    Code ( (Unknown Language)):
    1. org 000h
    2. start: mov P0,#11110000b; Turn on LED on P0.0 - P0.3
    3.        call delay       ; call delay time
    4.        mov P0,#00001111b; Turn on LED on P3.4 - P0.7
    5.        call delay; call delay time
    6.        sjmp start; loooooop forever to start
    7. ;=============================================
    8. ;subroutine delay created to rise delay time
    9. ;=============================================
    10. delay: mov R1,#255
    11. del1:  mov R2,#255
    12. del2:  djnz R2,del2
    13.        djnz R1,del1
    14.        ret
    15. end
    Attached are images of the breadboard and the programmer.
    Any help would be greatly appreciated.
    Thanks in advance,
    Doc
    :confused:
  2. doggiedoc
    Dec 16, 2004
    51
    bump
    Any advice/help would be greatly appreciated.
    Doc
  3. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    In my oppinion the leads to the crystal are to long.
    Keep the lines to the crystal as short as possible.
    Try to place the cryatsl near the processor.
    Greetings,
    Bertus
  4. doggiedoc
    Dec 16, 2004
    51
    Thanks for the reply - I'll try that tonight when I get home.
  5. doggiedoc
    Dec 16, 2004
    51
    Thanks for the tips there Bertus. Unfortunately it didn't help. :(
    I found a pre-made programmer at Sunrom.com - I think I'll just order that. It comes with software for windows too. :)
