ATMEL 89C51 PROGRAMMING need ur help
Discussion in 'Programmer's Corner' started by arikrishnan, Mar 28, 2007.
  1. arikrishnan
    Mar 7, 2007
    5
    sir,
    for programming we use "h" to refer hexadecimal number.for example
    MOV R2,#0FFH .
    similarlly what is used 2 refer decimal number.? is it necessary to initialise the use of decimal in ATMEL89C51 programming.
    MOV R3,#00D
    what is the meaning of the D used in above programme.
    please reply as soon as possible
    please reply to my mail id arikrishnan_t@yahoo.com
  2. Papabravo
    Feb 24, 2006
    10,338
    1,850
    If the assembler supports it, the "D" stands for decimal. Decimal is the default radix in most assemblers which is why the suffix H is required. Assemblers often have a "radix" pseudo operation to change the default radix. Which assembler are you using?
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    One must imagine that 00D = 00H, & 00B, not to mention 00O.
  4. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Truly, you have a dizzying intellect. I'm in awe.
  5. arikrishnan
    Mar 7, 2007
    5
    thanks 4 ur reply. did the ATMEL89C51 microcontroller accepts this type of code ("d" for decimal). do u have any sample programme for the same type . please send me
  6. Papabravo
    Feb 24, 2006
    10,338
    1,850
    The IAR assembler, that I have, does not appear to accept the D suffix on an integer constant.
