ATMEGA328P register regarding
selvamurugan_t
Joined Aug 8, 2016
18
Hi
I am new to ATMGEA microcontroller .I have started to check the LED program.It working
Line 1: DDRB |= 1 << PINB0;
Line 2: _delay_ms(100);
Line 3: PORTB &= ~(1 << PINB0);
Line4: _delay_ms(100);
In Line1: what i understand means
PINB0= 0000 0001
After 1<<PINB0
PINB0=0000 0010;
DDRB |=0000 0010;
my question is sum+=rem means sum=0+rem value;
Here what will be DDRB value and OR function with 0000 0010;
30,795
PINB0 = 0
1 << PINB0 results in 1
This is always inefficient code if the compiler does no optimization.
I prefer to use a bit mask
PINB0_MASK = 0x01
DDRB |= PINB0_MASK
Better still, do it in a header file
#define PINB0_MASK 0x01
sum += rem is the same as sum = sum + rem
DDRB |= 0x01 is the same as DDRB = DDRB | 0x01
The purpose of this code is to set bit-0 of DDRB while leaving all other bits unchanged.
selvamurugan_t
Joined Aug 8, 2016
18
PINB0 = 0
PINB0_MASK = 0x01
DDRB |= PINB0_MASK
SO you are saying DDRB=0b0000 0000 | 0b0000 0001
and result is =0x0000 0001
I am correct.
Reset of the registers all the bits initialized with 0000 0000 correct or not
30,795
I am correct.
That is correct.
But
DDRB |= 0b0000 00001
is not
DDRB = 0b0000 0000 | 0b0000 0001
That is not correct.
This instruction sets bit-0 of DDRB to 1.
