I am designing a development board using ATMEGA 32 and also has other IC's like FT232 and a regulator 1117 (5 volts). Many sensors and LCD are still to be connected.
In the board I am getting all the desired voltage levels at all points but still the circuit is not working. Is there any problem with the current flow because when i measured current, it was just 15 mA on entire board. If yes, then how am I supposed to fix it ? Please help
I have used a double sided PCB which is self made(using EAGLE)
Additional Details
i havent used autoroute facility and have made it by hand. I am using a 16 Mhz crystal. Also, since all the ic's are surface mounted i could not test on the bread board. Although, circuit is fine.
The problem is I am getting voltage across the power on led of atmega but still its not glowing and also the atmega32 is not getting programmed
Help please help
Additional Details
Help please help
