atmega16 pins trouble
Discussion in 'Homework Help' started by jose_007, Jul 7, 2012.
  1. jose_007
    May 3, 2011
    24
    A few pins of atmega16 (D0,D1,D2) are always high when uC is powered.Does it mean those pins are damaged ??
    Or is there a way to reset those pins to low ?
    ** I have tried programming the output of those pins
    jose
  2. jose_007
    May 3, 2011
    24
    Request to moderator
    Can you please move this thread to General electronics section ?
  3. MrChips
    Oct 2, 2009
    12,642
    3,456
    Simple way to tell, try another chip.
    Or try connecting 4k7Ω (or anything from 1k to 10kΩ) from the pin to GND and see if the voltage is still high.
  4. Jony130
    Feb 17, 2009
    3,993
    1,116
    Which pins you have in mind?
    D0 = PB0 ?? or what ?
  5. jose_007
    May 3, 2011
    24
    @Jony130
    PD0,PD1,PD2
  6. Jony130
    Feb 17, 2009
    3,993
    1,116
    Have you set DDRD to 1 and set PORD = 0
    Or maybe by accident you enable USART?
  7. jose_007
    May 3, 2011
    24
    i set port D to 0
    No , I didnt enable USART
    Also, pins C5,C6 show the same problem ...
  8. Jony130
    Feb 17, 2009
    3,993
    1,116
    Show as your program code.
  9. jose_007
    May 3, 2011
    24
    void main(void)
    DDRD=0x00;
    DDRA=0xFF;
    DDRB=0x00;
    DDRC=0x00;
    PINB=0x00;
    PINC=0x00;
    PIND=0x00;
    PORTA=0x00;
    <.......code.......>
    I am using D as i/p port and A as o/p port...but as precaution I set B and C to 0 as well.....
    Kindly point the error
  10. bretm
    Member
    Feb 6, 2012
    152
    24
    Does the chip have a bootloader installed? If so, it might enable UART before main() starts. Explicitly disable subsystems you don't need. This also helps battery life if applicable. Also see the PRR register which is often overlooked.
  11. jose_007
    May 3, 2011
    24
    I just burned the hex file...so I think bootloader is already installed
    Can you elaborate please...
    And kindly explain cause of pins C5 and C6
