sage.radachowsky
- Joined May 11, 2010
- 241
zxsa and toffee_pie: thanks for the replies
Most op amps can source up to 30 mA or so... you can directly maintain a voltage using an op amp in a feedback loop, with a 10 Ohm resistor in the path... but take the feedback *after* the resistor so it maintains the voltage there, and it will not vary much.
You will need a reference to go to the "+" input of the op amp, and a decoupling cap. Use a 9V battery is good enough for this.
