Hi all,
Last couple of days I have started with my Atmega 644 (still had it arround from a previous project which did not start).
However I am capable of building an blinking led (without troubles), based on delay.h I am not capable in adding a serial port interface.
On the net I have not found a lot of info for the 644, since it is a little different with its registers. I think I have set them all correctly, but as said I get strang output (after code snippet examples):
If I configure my realterm as such:
- 8bit
- 1 stop
- no flow ctrl
- no parity
And send the char "a" I get "RXQ" in return, where I would be expecting "[a]".
Can someone advise me what I am doing wrong. I have read all options in the datasheet, but I cannot figure out by myself.
Furthermore connecting tx and rx directly give response on the console like "a" or "b".
Code:
A simple program to demonstrate the use of USART of AVR micro
Hardware:
ATmega644 @ 20MHz
Suitable level converter on RX/TX line
Connected to PC via RS232
PC Software : Hyper terminal @ 9600 baud
No Parity,1 Stop Bit,
Flow Control = NONE
#ifndef F_CPU
#define F_CPU 20000000UL
#endif
# define USART_BAUDRATE 9600
# define BAUD_PRESCALE ((( F_CPU) / (16UL * USART_BAUDRATE) ) - 1)
#include <avr/io.h>
//This function is used to initialize the USART
//at a given UBRR value
void USART_Init( unsigned int baud ) // Extracted function from the datasheet
/* Set baud rate */
UBRR0H = (unsigned char)(baud>>8);
UBRR0L = (unsigned char)baud;
/* Enable receiver and transmitter */
UCSR0B = (1<<RXEN0)|(1<<TXEN0);
/* Set frame format: 8data, 1stop bit */
UCSR0C = (3<<UCSZ00);
//This function is used to read the available data from USART. This function will wait until data is
//available.
unsigned char USART_Receive( void ) // Extracted function from the datasheet
/* Wait for data to be received */
while ( !(UCSR0A & (1<<RXC0)) )
/* Get and return received data from buffer */
return UDR0;
//This function writes the given "data" to the USART which then transmit it via TX line
void USART_Transmit( unsigned char data ) // Extracted function from the datasheet
/* Wait for empty transmit buffer */
while ( !( UCSR0A & (1<<UDRE0)) )
/* Put data into buffer, sends the data */
UDR0 = data;
int main(void)
//Variable Declaration
char data;
USART_Init(BAUD_PRESCALE);
//Loop forever
while(1)
//Read data
data=USART_Receive();
/* Now send the same data but but surround it in
square bracket. For example if user sent 'a' our
system will echo back '[a]'.
USART_Transmit('[');
USART_Transmit(data);
USART_Transmit(']');
- 8bit
- 1 stop
- no flow ctrl
- no parity
