ATMEGA 328P equivalent PIC
Discussion in 'Embedded Systems and Microcontrollers' started by camerart, Oct 6, 2016.
  1. camerart
    Thread Starter Active Member
    Feb 25, 2013
    518
    30
    I'm looking for an ATMEGA328P PIC equivalent.
    Will the 18F4520 do?
    Cheers, Camerart.
  2. joeyd999
    Jun 6, 2011
    2,757
    2,936
    The correct MCU is the one that has at least the minimum hardware available to do the job. The hardware differences between the Atmega and PIC are enough to say that there is no "equivalent" -- as in, drop in replacement.
    Don't choose a replacement based upon the corresponding capabilities of the original part. Choose it based upon the requirements of the project.
  3. camerart
    Feb 25, 2013
    518
    30
    Hi J,
    Thanks.
    I'm working with a circuit that uses the ATMEGA328P, and hoped someone, could advice me on a PIC that will do tha same job. My system can't program the ATMEGA.
    C.
  4. dannyf
    Sep 13, 2015
    2,196
    417
    Depending on what you mean by dependency. For example, no low end pic has vectored interrupts.
  5. upand_at_them
    May 15, 2010
    246
    29
  6. jayanthd
    Member
    Jul 4, 2015
    275
    29
    What features do you need in the PIC18F ? Try PIC18F26K22.
  7. camerart
    Feb 25, 2013
    518
    30
    Hi all,
    Thanks. I have the Microchip comparitor.
    Trouble is,it's a bit of a chicken and egg situation. I'm trying to get some RFM modules to work with Oshonsoft basic programming which doesn't fully cover the Atmega chips, so I have to use one that's supported.
    What I'll do is make a veroboard circuit with an 18F4520, till I understand better how they work, then I'll know how to choose.
    Cheers, Camerart.
