AT91SAM7X512's SPI peripheral gets disabled on write to SPI_TDR
Discussion in 'Embedded Systems and Microcontrollers' started by dor, Mar 18, 2010.
  1. dor
    Thread Starter Active Member
    Feb 20, 2009
    62
    My AT91SAM7X512's SPI peripheral gets disabled on the X time (X varies) that I write to SPI_TDR.
    As a result, the processor hangs on the while loop that checks the TDRE flag in SPI_SR. This while loop is located in the function SPI_Write() that belongs to the software package/library provided by ATMEL.
    The problem occurs arbitrarily - sometimes everything works OK and sometimes it fails on repeated attempts (attemp = downloading the same binary to the MCU and running the program).
    Configurations are (defined in the order of writing):
    1. SPI_MR:
      • MSTR = 1
      • PS = 0
      • PCSDEC = 0
      • PCS = 0111
      • DLYBCS = 0
    2. SPI_CSR[3]:
      • CPOL = 0
      • NCPHA = 1
      • CSAAT = 0
      • BITS = 0000
      • SCBR = 20
      • DLYBS = 0
      • DLYBCT = 0
    3. SPI_CR:
      • SPIEN = 1
    After setting the configurations, the code verifies that the SPI is enabled, by checking the SPIENS flag.
    I perform a transmission of bytes as follows:
    Code ( (Unknown Language)):
    1. const short int dataSize = 5;
    2. // Filling array with random data
    3. unsigned char data[dataSize] = {0xA5, 0x34, 0x12, 0x00, 0xFF};
    4. short int i = 0;
    5. volatile unsigned short dummyRead;
    6.
    7. SetCS3();    // NPCS3 == PIOA15
    8. while(i-- < dataSize) {
    9.     mySPI_Write(data[i]);
    10.     while((AT91C_BASE_SPI0->SPI_SR & AT91C_SPI_TXEMPTY) == 0);
    11.     dummyRead = SPI_Read();    // SPI_Read() from Atmel's library
    12. }
    13. ClearCS3();
    14. /**********************************/
    15. void mySPI_Write(unsigned char data) {
    16.     while ((AT91C_BASE_SPI0->SPI_SR & AT91C_SPI_TXEMPTY) == 0);
    17.     AT91C_BASE_SPI0->SPI_TDR = data;
    18.     while ((AT91C_BASE_SPI0->SPI_SR & AT91C_SPI_TDRE) == 0); // <-- This is
    19.     // where the processor hangs, because that the SPI peripheral is disabled
    20.     // (SPIENS equals 0), which makes TDRE equal to 0 forever.
    21. }[/i]
    Questions:
    1. What's causing the SPI peripheral to become disabled on the write to SPI_TDR?
    2. Should I un-comment the line in SPI_Write() that reads the SPI_RDR register?
      Means, the 4th line in the following code: (The 4th line is originally marked as a comment)
      1. void SPI_Write(AT91S_SPI *spi, unsigned int npcs, unsigned short data)
      2. {
      3.     // Discard contents of RDR register
      4.     //volatile unsigned int discard = spi->SPI_RDR;
      5.
      6.     // Send data
      7.     while ((spi->SPI_SR & AT91C_SPI_TXEMPTY) == 0);
      8.     spi->SPI_TDR = data | SPI_PCS(npcs);
      9.     while ((spi->SPI_SR & AT91C_SPI_TDRE) == 0);
      10. }
    3. Is there something wrong with the code above that transmits 5 bytes of data?
    Please note:
    • The NPCS line num. 3 is a GPIO line (means, in PIO mode), and is not controlled by the SPI controller.
      I'm controlling this line by myself in the code, by de/asserting the ChipSelect#3 (NPCS3) pin when needed.
      The reason that I'm doing so is because that problems occurred while trying to let the SPI controller to control this pin.
    • I didn't use the PDC/DMA controller and prefer not using it.
    • I didn't reset the SPI peripheral twice, because that the errata tells to reset it twice only if I perform a reset - which I don't do. Quoting the errata:
    • I noticed that sometimes, if I put a delay before the write to the SPI_TDR register (in SPI_Write()), then the code works perfectly and the communications succeeds.
    Useful links:
    An example of initializing the SPI and performing a transfer of 5 bytes is highly appreciated and helpful.
    Thank you.
    Best regards,
    Dor.
