AT89S51 USB PROGRAMMER
Discussion in 'Embedded Systems and Microcontrollers' started by Lanz, Mar 28, 2009.
  1. Lanz
    Thread Starter Active Member
    Oct 30, 2008
    153
    Hi,im working up some projects using Atmel's at89s51.
    I had searched at the shop for the programmer(downloader) and found that its too expensive.
    So,i want to do a simple programmer for at89s51 so that i can upload hex file from my laptop to the chip at my home.
    Is there any possible to do a simple circuit as i mentioned above using usb port because im using laptop?
    And i need some simulator for this uc.Can suggest some?
  2. Arm_n_Legs
    Mar 7, 2007
    183
    10
  3. Lanz
    Oct 30, 2008
    153
    Thanks for the info arm n legs.
    But i want to transfer the hex code via usb replacing serial port.
    Is that possible?
  4. Arm_n_Legs
    Mar 7, 2007
    183
    10
    If you want to download hex code to the 8051 via USB, then i will suggest that you use the Atmel AT89S5131 which is a 8051 derivative. This chip has a USB port and can directly receives hex code via USB from the PC using a free software called the Atmel FLIP.
  5. adventtech
    Member
    Feb 10, 2009
    22
    Hi
    There is one very simple USB programmer for At89S mcu at ebay
    http://cgi.ebay.co.uk/Atmel-AT89S51-52-2051-4051-USB-Programmer-ISP-ZIF_W0QQitemZ270416838576QQcmdZViewItemQQptZUK_BOI_Electrical_Components_Supplies_ET?hash=item3ef6197fb0&_trksid=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1683|240%3A1318|301%3A1|293%3A1|294%3A50
  6. secrect
    Member
    Feb 1, 2009
    16
    AT89S5131 ? datasheet please!
  7. arnabc
    Sep 16, 2010
