At89s51 microcontroller based annunciation system with led display
Discussion in 'Embedded Systems and Microcontrollers' started by varalakshmisethepalli, Mar 14, 2010.
  1. varalakshmisethepalli
    Mar 14, 2010
    this circuit uses AT89S51 MICROCONTROLLER.and voice chip APR9600.PLZ SEND ME THE LANGUAGE OF THE CODE AND DETAILS FOR UNDERSTANDING THAT CODE.
    Include $regfile
    Include Reg51.dat
    'Trigger input
    Inp1 Var P0.0
    Inp2 Var P0.1
    Inp3 Var P0.2
    Inp4 Var P0.3
    Inp5 Var P0.4
    Inp6 Var P0.5
    Inp7 Var P0.6
    Inp8 Var P0.7
    'LED - Outputs
    Ledout Var P1
    Led1 Var P1.0
    Led2 Var P1.1
    Led3 Var P1.2
    Led4 Var P1.3
    Led5 Var P1.4
    Led6 Var P1.5
    Led7 Var P1.6
    Led8 Var P1.7
    'Voice Outputs
    Trig1 Var P2.0
    Trig2 Var P2.1
    Trig3 Var P2.2
    Trig4 Var P2.3
    Trig5 Var P2.4
    Trig6 Var P2.5
    Trig7 Var P2.6
    Trig8 Var P2.7
    Main
    Temp = 0
    Do
    If Inp1 = 0 Then Goto Msg_1
    If Inp2 = 0 Then Goto Msg_2
    If Inp3 = 0 Then Goto Msg_3
    If Inp4 = 0 Then Goto Msg_4
    If Inp5 = 0 Then Goto Msg_5
    If Inp6 = 0 Then Goto Msg_6
    If Inp7 = 0 Then Goto Msg_7
    If Inp8 = 0 Then Goto Msg_8
    End If
    Loop
    Msg_1
    Reset Led1 : Reset Trig1
    Incr Temp
    If Temp = 15 Then Goto Alarmmode
    Bitwait Reset_sw , Reset
    Set P1 : Set P2 : Reset Bz : Reset Relay
    Goto Main
    End If
    Msg_2
    Reset Led2 : Reset Trig2
    Incr Temp
    Goto Main
    End If
    Msg_3
    Reset Led3 : Reset Trig3
    Incr Temp
    Goto Main
    End If
    Msg_4
    Reset Led4 : Reset Trig4
    Incr Temp
    Goto Main
    End If
    Msg_5
    Reset Led5 : Reset Trig5
    Incr Temp
    Goto Main
    End If
    Msg_6
    Reset Led6 : Reset Trig6
    Incr Temp
    Goto Main
    End If
    Msg_7
    Reset Led7 : Reset Trig7
    Incr Temp
    Goto Main
    End If
    Msg_8
    Reset Led8 : Reset Trig8
    Incr Temp
    Goto Main
    End If
    Alarmmode
    Set Relay
    Set Bz
    Goto Main
