at89c52 Code Banking
Discussion in 'Embedded Systems and Microcontrollers' started by bctang, Oct 12, 2008.
  1. bctang
    Sep 5, 2004
    26
    Please can anyone help me?
    I'm using at89c52. Can you guide me how to do the configuration keil code banking?
    I have do some testing. I create x1 common x3 bank's. After i compiled, it just generate the 3 bank hex file. May i know how to generate the common.c hex file? Is it necessary to have common.hex to burn into MCU? The x3 bank.hex will be in to EPROM.
    Please can you check for me is it the circuit correct not?
    Thank you very much.....
    • Code.zip
      File size:
      138.8 KB
      27
