At the moment I have a project involving running 3 motors via a micro controller, the user controls the motors using a 3-axis joystick connected to a computer.
I have the joystick working perfectly, and the program sending the serial data packet to the micro correctly (I used a couple of serial port monitors to check this). The data sent is ASCII characters.
So the problem I'm having is that the micro only understands a section of the data being sent, it understands the automatic address character, the end of packet characters and the first 3 data characters, but not the rest. I'm sending a 15 character array including the address and the end chars.
i.e. if I send a12345678911ff it will reckonise the automatic address character 'a' and the end characters 'ff' and the '123' but not the rest.
The idea with the packet is to use each group of 3 to control each motor and the last 2 characters to choose whether the motors should be on or off.
I've added the serial interrupt method so you can see whats being done, basically I take the data from the serial buffer and put it in an array, I then use another method to convert the ASCII char to an int so that the PWM can be set.
I appreciate the help
Steve
Steve
Rich (BB code):
interrupt void Serial(){
if(TI == 1){ //check for the transmit flag
TI = 0; //clear the flag
transmit = 1; //clear the global flag used for transmitting
if(RI == 1){ //check for the receive flag
UART_received = 1; //set the flag to indicate that the UART byte has been received
if(SM2 == 1){ //check to see if the automatic address is set to high
SM2 = 0; //turn off the address recognition and set it to data mode
RI = 0; //clear the receive flag
i = 0; //reset the global pointer to 0
else { //ready for the data transmission
buffer = SBUF; //extract the information and store it inside the array
if((buffer == 0x66 || 0x46) && (flag == 1)){ //check if the termination bit is a f and check the previous character
SM2 = 1; //if the last 2 characters have been ff turn back on the address recognition
flag = 0;
complete = 1;
i=0;
else if(buffer == 0x66|| 0x46){ //if this is the 1st f wait for another one
flag = 1; //set the 1st f flag high
i++; //increment the array position
RI = 0; //clear the flag
else{ //otherwise it is a normal byte coming in
