1. tharunmalli
    Apr 7, 2014
    12
    I am doing a project using AT89C2051 microcontroller, I am finding difficulty in doing serial communication. I connected RS232,MAX232 and controller, please help how to download the program on chip and run it. I am using kiel software
  2. shteii01
    Feb 19, 2010
    3,500
    511
  3. tharunmalli
    Apr 7, 2014
    12
    thanks for the reply,,
    actually I built the simple hardware kit using the AT89C2051, Max232 , rs232 and other necessary connection.Now my problems are
    1.How to download a simple program of led blinking on to the chip from pc using keil software,, please send the detailed procedure.
    2.some say that rs232 is not compatible to my system though i have D9 connector in my system, Is there any software which can be used to make it compatible.
    3.whether RS232 connected to the system provide power supply to both the Max232 and AT89C2051 or we need to provide separate supply to controller
    please help me in this regard
  4. tharunmalli
    Apr 7, 2014
    12
    I am using p89v51rd2 for my project... I dumped the program on it using flash magic.. Can I take out that ic and use it in the other circuit so that it works based on the progarm dumped on it
  5. embpic
    Member
    May 29, 2013
    187
    yes u can use it out of programmer circuit. as you burn the code in flash then u can use this program till the next programm burn or ic get burn.
