I'm considering rolling my own one-off buck converter. I need 14-20V in, 24V out, 3A. I am looking at using the LM2577-ADJ, which has a switching frequency of 52KHz. Is that going to cause an issue if I breadboard it or throw it together on a veroboard with questionable routing and sloppy soldering?
If so, can someone recommend a lower frequency circuit design that uses a 555 or something, that might be more suited to "rapid prototyping "?
