at a total loss with mesh analysis and need help
Discussion in 'Homework Help' started by hunterage2000, Mar 18, 2011.
  1. hunterage2000
    Thread Starter Active Member
    May 2, 2010
    402
    At a bit of a loss with mesh current analysis and cant see what is going on with it. I can grasp Node analysis but dont really understand mesh. Can someone look at the attached jpeg and talk me from start to finish how this is solved?
  2. hunterage2000
    May 2, 2010
    402
    no takers? No one can spend 5 minutes to show me how to answer this?
  3. justtrying
    Mar 9, 2011
    329
    398
    have you tried setting up the equations? there are three loops, therefore three equations to solve a matrix ;)
  4. hunterage2000
    May 2, 2010
    402
    I've tried with what I think is right but LTspice says its wrong. But to be honest I dont fully understand what Im meant to be doing.
  5. justtrying
    Mar 9, 2011
    329
    398
    I understand, still try writing the three loop equations - see attachment.
    I1R11+I2R12+I3R13 = V1
    I1R21+I2R22+I3R23 = V2
    I1R31+I2R32+I3R33 = V3
    where R11, R22 and R33 are resistances within the loops and R12, R13 etc are resistances shared by the currents. When you assign the currents, the direction is arbitrary, as you work through the equations, when you do the resistances shared by the loops, if two currents go in opposite direction, the sign is negative, if they go in the same direction the sign is positive.
    The other danger is sign for the voltage - again see how it is with respect to your assigned current.
    I got I1 = -15.14A (that means it is actually opposite to my assigned direction)
    I2 = 3.396A and I2=0.2539A. I would imagine the problem actually asks about currents through resistors, so you would then have to add your mesh currents to find actual circuit currents. Checked this on multisim, got exact values.
  6. hunterage2000
    May 2, 2010
    402
    I have tried again and got the wrong answers. Can you show me what you got for the 3 equations
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    You should to write out the three equations as suggested by justtrying.
    For instance for loop I1
    7*I1-4*I3=-107
  8. justtrying
    Mar 9, 2011
    329
    398
    you should post your equations so that we can help you figure out what is wrong, most likely source of error is signs. Right now al info you need to write the equations is there. ;)
