asynchronous communications-Error detection
Discussion in 'Homework Help' started by dhammikai, Sep 12, 2009.
  1. dhammikai
    Sep 12, 2009
    10
    Please help me to find the solution for following;
    Assume an asynchronous communications protocol with 1 start bit, 2 stop bits, 1 parity bit, and 7 data bits. Assume that the start and stop bits are never in error, but for the remaining bits the Bit Error Probability = 0.05 (bit errors are independent).
    Then need to be find the probability that a received word is error-free? and
    Need to find highest possible probability of bit error if the probability that a received word is error-free must be no less than 0.80?
  2. dhammikai
    Sep 12, 2009
    10
    My email [has been removed by moderator]
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    So what are your initial thoughts on how we might approach the solution?
    An 8 bit number can have no errors, or any number of errors from 1 to 8. It is just like coin flips with p(Heads) = 0.95 and p(Tails)=.05 -- Isn't it?
  4. dhammikai
    Sep 12, 2009
    10
    Hi thanks for the reply and commnets...but I am in stuck with my problem, but I found one PDF file (Attached here with) In the attachment question 07 is same as the my one but couldn't understand how it is solved.....
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Do you know what "independent identically distributed" means, and why it is important in this context? If not, then you need to go back and review this concept. Now a simpler problem. You have a "fair" coin with p(Heads) = p(Tails) = 0.5. If each flip is independent and the distribution remains the same for each flip; what is the probability of getting two heads out of two flips? Isn't your problem the same except for the probabilities (an unfair coin) and the number of trials?
  6. dhammikai
    Sep 12, 2009
    10
    According to the question they ask about error probability..
    This asynchronous communication has a 1 start bit, 2 stop bits, 1 parity bit, and 7 data bits.
    here that the start and stop bits are never in error.
    We needs to concern about remaining bits the Bit Error Probability = 0.05 (bit errors are independent).[The remaining 8 bits has 0.05 (5%) error probability. It means bit has 5% error probability (it also means 95% is error free probability)]
    The answer should be " What is the probability that a received word is error-free?" is 95%, isn't it? I need Ur comments again..
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    No it is not, and please don't restate the problem, I got it the first time and it creates a bad impression when you do that. Each bit may be regarded as an independent trial, aka flip of a coin. Each trial has p(Error) = 0.05 and p(No Error) = 0.95. The p(NoError) over 8 bits is most certainly not 0.95 Go back and review the material on repeated trials or Bernouli trials. If that does not make the light bulb go on, then take a coin and flip it 8 times. Did you get eight heads in a row? No then do it another 8 times, UNTIL you get eight heads in a row. How many times did it take you before you got eight heads in a row. Now assume the coin is unfair such that p(Heads) is 0.95 and the p(Tails) is 0.05 and ask what is the p(8 heads in a row), and you will have your answer.
  8. dhammikai
    Sep 12, 2009
    10
    OK Thanks, Now I have idea about solutions.. Thanks so much
