astable oscillator question
Discussion in 'Homework Help' started by bug13, Jul 18, 2012.
  1. bug13
    Feb 13, 2012
    1,214
    38
    as seen in picture below, when i hook up the oscilloscope to outA and gnd, I can get about 1Hz, but when I connect it to OutB, I somehow get a Sine wave, what could be wrong? I am guessing one of the NAND gate is tossed?
    I should get a 22kHz square + 1HZ square wave on OutB.
    note: In is always high, and the OutA on the second one should be labeled OutB
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    My guess is you are beating the two frequencies together, which would create a sine wave. Just a guess though. Try each oscillator separately and see what it does.
  3. mlog
    Member
    Feb 11, 2012
    276
    36
    What's the value of the resistor at the bottom? 220 or 22k or something else?
  4. bug13
    Feb 13, 2012
    1,214
    38
    sorry about my writing, it's 22k
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    What's the sinewave frequency you see on the CRO - maybe it's 50Hz due to CRO signal grounding oversight.
    I'm assuming you have actually built the circuit.
    The output should be a gated pulse train at the nominal conditions - if the primary astable is indeed 1Hz then you would expect approx 500ms bursts at the second astable frequency [22kHz?]. However, I'd check your values do actually give those stated frequencies.
    bug13 likes this.
  6. bug13
    Feb 13, 2012
    1,214
    38
    Sorry, the second should be around 2kHz, my mistake.
    the circuit was built, I will need to go back to school to check the frequency tomorrow.
    And can you explain a bit more on this one, I think I get your idea, but I am not sure if I got right idea tho.
    And another thing, how robust is a NAND gate, I am thinking I might tossed one of the NAND gate, as connect the positive to the wrong when I first hooked it up to the scope.
  7. absf
    Dec 29, 2010
    1,493
    374
    Then the wave should look something like the attached....
    Top = Out_A
    bottom = Out_B
    Allen
    bug13 likes this.
  8. t_n_k
    Mar 6, 2009
    5,448
    783
    If you leave the signal ground off the circuit connection [by mistake or due to a connection fault] often you will see 50Hz [or 60Hz] mains 'noise' picked up on the CRO active. I would see 50Hz here in Australia.
    If you have a spare chip it might be worth checking the problem is elsewhere rather than with a damaged gate(s).
  9. bug13
    Feb 13, 2012
    1,214
    38
    I can only get 1Hz with my physical connection, but I can't even get 1Hz in multisim, is it the right connection below???
  10. t_n_k
    Mar 6, 2009
    5,448
    783
    I've not used Multisim but I note your sim schematic has no ground node.
  11. bug13
    Feb 13, 2012
    1,214
    38
    I have checked it, it is exactly what you said, thanks
