Astable multivibrator 555 problem in circuit
Discussion in 'Homework Help' started by faria_syd, Aug 29, 2015.
  1. faria_syd
    Aug 29, 2015
    11
    http://www.electronicshub.org/super-sensitive-intruder-alarm/
    Hey i am a 3rd year engg student doing this project. The sensor part is working but alarm is not ringing.. I am using an 8ohms speaker and R4 n R5 as 1k. Please suggest changes that would make it work and should i use a buzzer instead of speaker. please give complete details as i am not very well versed with 555 working
  2. ericgibbs
    Jan 29, 2010
    2,595
    393
    hi Faria,
    Have you calculated the frequency of the Astable with 1K's for R4&5 with a 0.01uF cap.??
    E
    faria_syd likes this.
  3. faria_syd
    Aug 29, 2015
    11
    48khz is the frequency. Should that be altered?
  4. ericgibbs
    Jan 29, 2010
    2,595
    393
    You will not hear 48kHz, design for for around 3kHz, this a frequency we can hear OK.
    Try R4 and R5 at 10K, that should be around 5kHz, lets know how it goes.
    E
    EDIT:
    If you want close to 3kHz, use 15k's
  5. faria_syd
    Aug 29, 2015
    11
    Is a coupling capacitor of 10uf before speaker okay or i need to use some other value
  6. ericgibbs
    Jan 29, 2010
    2,595
    393
    hi f,
    For a simple 'sounder' a 10uF thru 100uF should be OK.
    Let me know when it works.
    E
  7. faria_syd
    Aug 29, 2015
    11
    I used R1as 56k n R2 as 10k with C 0.01u
    It works extremely well now. Thanks Eric
  8. ericgibbs
    Jan 29, 2010
    2,595
    393
    hi,
    That is approx 3.2kHz.:)
    I have found that a frequency around 3kHz is quite a penetrating tone.
    E
  9. faria_syd
    Aug 29, 2015
    11
    Thanks once again.. Now i can b assured of great grades coz of ur help
