On what do you base this claim? Why wouldn't tactile switches exhibit switch bounce? And ANY bounce is too much bounce when dealing with a edge-sensitive circuit.I think the switches are tacticle so they shouldn't have too much bounce.
It's easiest to do if you use SPDT switches. Then you can just use an RS latch made using two NAND gates (so a single quad NAND gate part can debounce two switches). With a SPST switch it is a bit harder, but often using a suitably-sized RC low-pass filter will do the trick. In this application you have the advantage of not being too sensitive to missing an initial pulse and can accept that possibility as the price to ensuring that you don't get spurious pulses.Is it easy to eliminate switch bounce?
