Assistance please with a flood light problem
Discussion in 'General Electronics Chat' started by Seaker, Feb 10, 2013.
  1. Seaker
    Feb 3, 2013
    32
    I have a conventional yard flood light that is now giving me a problem. The problem is that the timer that can be set to determine the amount of time that the light stays on is not working correctly all of the time.
    I can have the light connected and it works well for 5 days then for some reason the light does not shut off and stays on all night. When I manual shut off the light (cut the power) then turn the power back on it will function correctly for a few days and then will not shut off again. All other functions are working OK.
    I am hoping that some one might be able to start me off in getting this light working well again.
    In the interest of providing additional information which might be of help I have included the following as well as an image of the flood light!
    This unit contains three small pots which can be set to ones requirements.
    The electronics is provided on 2-small boards, one for the AC-DC conversion the other the circuitry for the flood light.
    I removed the electronics from the light and it consists of the following:
    A power supply board which contains:
    A relay switch 7amps AC 250 Volts, as well as the expected 4 power supply diodes and 3 large capacitors, a transistor and a few resisters.
    The electronics board contain the following
    1-LM432N IC
    1- IR Detector
    1- Photo resister
    3 Pots for setting the sensitivity of the IFR Sensor, sensitivity to the Photo resister and finally a Pot for setting the Light – On duration.
    ( It is here that I have the problem).
    I thank you in advance for any assistance you might be able to provide.
  2. sheldons
    Oct 26, 2011
    616
    101
    can you give me a photo of the pcb used (top and bottom) as there are a few different version boards used
  3. #12
    Nov 30, 2010
    16,660
    7,305
    My first impression is, squirt some contact cleaner in the pots. A bit of dirt and they will not conduct.
  4. Seaker
    Feb 3, 2013
    32
    Thank you all for the response!
    I will try and answer all of the questions asked and or provide more information.
    The unit was purchased by me from a supplier here in Thailand. The unit is made here or in China.
    I am providing two additional images which I hope helps. I think that you can see that the photosenser is a Photo resister
    [​IMG].
    I had thought that the problem could be a cold solder joint or an issue with the timing pot, but as I am a bit of a newbie I wanted to ask for assistance.
    The comment about using a contact cleaner to try and clean the Pots is a good one. I have checked all of the solder points and they appear fine.
    I hope that this information is of use and thank you again for your responses.
  5. takao21203
    Distinguished Member
    Apr 28, 2012
    3,577
    463
    Cheap relay maybe. The contacts fry together. As a halogen lamp has very low cold resistance this is likely.
    Replace with contactless relay module. Or high quality relay.
    I saw this behaviour for a small motor (which of course has a high startup current). After some months, it would stay on sometimes.
  6. gerty
    Aug 30, 2007
    1,154
    304
    Is this light controlled from a light switch? There are some out there that let you bypass the motion detector by flipping the switch on/off a couple of times giving the results you describe.
  7. Brownout
    Jan 10, 2012
    2,375
    998
    I agree with post #6. I was gonna suggest this as the problem as I have the same problem with a motion controlled light. My problem shows up when it gets cold, which led me to suspect the E-M relay.
  8. Seaker
    Feb 3, 2013
    32
    I want to thank every one for taking the time to reply to this thread.
    After much testing I seem to have found and corrected the problem with the flood light.
    The problem was a dirty pot, I used a contact cleaner and the light works well now.
    Thanks again to all!
  9. #12
    Nov 30, 2010
    16,660
    7,305
    Sometimes I get lucky:D
  10. gerty
    Aug 30, 2007
    1,154
    304
    You nailed that one!!:D:D:D:D
