Assigning priorities among sensors
Discussion in 'General Electronics Chat' started by sri.jnana, Aug 29, 2013.
  1. sri.jnana
    Aug 29, 2013
    i want to implement some priority levels among the sensors connected to the micro controller. is it possible ?
    i mean depending on the priority the micro controller should send a message to the receiver if the sensor priority is high & if the priority is low then it should wait for some time & if the sensor output is high continuously for some time then only the controller should send the message.
    in which way i can assign priority among the sensors?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    This was neither feedback nor a suggestion, so I have moved it to a more appropriate forum.
  3. Shagas
    May 13, 2013
    802
    74
    Hmm I'm trouble understanding what you need to do . Could you try explain again ? or give draw a diagram of what you need ?
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Of course it is possible.
  5. MaxHeadRoom
    Jul 18, 2013
    10,863
    2,525
    There is also interrupts on input, as well as High and low interrupt priorities in the Pic18F.
    Max.
