Write a program that will move a character from left to right and then back again across the monitor of the PC a number of times as specified by the user's input. The user is to be prompted for the character to display and how many times to move it back and forth. An input of '?' and 1 would cause the '?' to move back and forth across the monitor 1 trip.
Your program must only allow entry of numbers from 1 to 5 inclusive. Use a loop that allows an exit only if the value is greater than zero and less than six. If the user enters an illegal value you must remind him/her of the values that are allowed and re-prompt for the numeric value. You do not have to do any error checking on the character as any printable character is fine.
Remember if you have just displayed a character the cursor will be just to the right of it. In order to display the next character you will have to erase the previous character and then display the character in the new location. The backspace character is character number 8 and a space is character number 32. Do not display a character in the 80th position as this will cause the cursor to advance to the next line. All output must be on the same line.
You will also have to write a procedure that will slow the cursor movement across the screen. A Pentium CPU will move the cursor so fast that the user will not see it move. Your delay procedure needs to be a loop that does nothing an appropriate number of times.
we are using intel 80 86, this how I start doing it
.model small
.586
.stack 100h
.data
Char db '?'
Num dw '?'
.code
include PCMAC.INC
main proc
_Begin
CallGetChar
CallGetNum
CallDisplayChar
_Exit0
main endp
Delay proc
Push ecx;
mov ecx,5000000
CharTop:
Nop
Dececx
JnzCharTop
Popecx
Ret
Delay endp
GetChar proc
Ret
GetChar endp
.model small
.586
.stack 100h
.data
Char db '?'
Num dw '?'
.code
include PCMAC.INC
main proc
_Begin
CallGetChar
CallGetNum
CallDisplayChar
_Exit0
main endp
Delay proc
Push ecx;
mov ecx,5000000
CharTop:
Nop
Dececx
JnzCharTop
Popecx
Ret
Delay endp
GetChar proc
Ret
GetChar endp
