Assembly problems
Discussion in 'Programmer's Corner' started by Dritech, Feb 19, 2012.
  1. Dritech
    Sep 21, 2011
    756
    5
    I have some questions regarding assembly programming for PIC18F:
    1) How to move the value from the working register to another register? do i have to use MOVFF w,REG1 ??
    2) Is STATUS,C low (0) when the value is negative?
  2. stahta01
    Member
    Jun 9, 2011
    133
    21
    FYI: There is likely several hundred assembly languages in the world; it would help if you stated the one you are using in the post you ask the question.
    I would even suggest having it in the thread title.
    Tim S.
  3. RiJoRI
    Aug 15, 2007
    536
    26
    First, take a look at the tutorials at http://gooligum.com.au/tutorials.html
    Then...
    1) You want to MOVe the Working register to a File.
    MOVWF Reg1 should do it.
    2) The data sheet will -- or should -- tell you the operation of the carry bit. Actually, it should be called the Carry/Borrow bit. The Datasheets I have tell you:
  4. MrChips
    Oct 2, 2009
    12,625
    3,451
    Well he did say he is programming a PIC18F.
  5. stahta01
    Member
    Jun 9, 2011
    133
    21
    FYI: Notice my post date and his edit time/date.
    Tim S.
