maxbotix.com EZ0 sensor
Above is a simple distance sensor I bought.
I want to turn on LED's for a distance to a wall warning device.
RED = stop!
Amber = Warning prepare to stop
Green = ok to drive
I will simulate using a Dragon 12+ plus microcontroller board and debug 12.
I need code for this in Assembler language.
Note:
Once I have it I want to consider sounds such that:
RED led = constant warning chime
Yellow = slow beep
Green = no beep
Flashing red LED = you are closer than 1.0 feet to a wall and are about to hit.
I will use the AN analog o/p of the maxbotix sensor.
The device turns out a voltage corresponding to the distance.
So, when you are at 5 feet or greater from a wall we should turn on a green LED.
If we are at 2.5 to 4.9 feet we should turn on a Yellow led.
If we are at 2.4 feet to 1.5 feet = red.
I have the idea that anything under 1.4 to 0 feet should flash a red led!!!
Does anyone have and idea how to do this or how to at least program the microcontroller so that it can illuminated the corresponding LED's?
RED = stop!
Green = ok to drive
Note:
Yellow = slow beep
Green = no beep
