Assembly Language Project need help!!!!
Discussion in 'Programmer's Corner' started by Leo_S, Oct 21, 2012.
  1. Leo_S
    Oct 21, 2012
    Can anyone help me with the project(Assembly Language) which is about the calendar for 3 months at least including OCTOBER of 2012
    I need a zip file with .asm and .com
    I have Win 7 64 bit
    PLZ help :|
  2. t06afre
    May 11, 2009
    5,939
    1,222
    would it not be wise to tell us which CPU/MCU you are working with. Would you also like us to write a report while we are at it:rolleyes:
  3. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    [ QUOTE=Leo_S;535241][ COLOR=#3e3e3e]Can anyone help me with the project(Assembly Language) which is about the calendar for 3 months at least including OCTOBER of 2012[ /COLOR]
    I have Win 7 64 bit
    PLZ help :|[ /QUOTE]
    Press F5,F7,F12,F5,F12,F7 in a row and then enter "QsDDaGGhhIajf".
  4. nigelwright7557
    May 10, 2008
    488
    71
    You at least need to have had a go at this yourself if you are expecting help on here.
    Unless of course you intend to pay for a solution ?
  5. atferrari
    Jan 6, 2004
    2,663
    783
    Did it and, more or less worked, but micro says 1912 :confused:
    The DeLorean seems to be somewhere in the Balkans. Not a good moment, really.
    Please correct and send it asap.
  6. takao21203
    Apr 28, 2012
    3,578
    463
    You need a Millenium mode crystal.
    http://youtu.be/0yYL3c6jkkM
    Then the calendar bits flip throgh like in the above video!
    One time I really wrote a game using the MSDOS debug. During later stages of developement, I used a real assembler. I did not use literature except a 386 book (which I borrowed from a library).
    Really can assembler be teached into all small details?
    If you want to learn assembler, then *WTH* just do something using assembler. Some kind of program or even a small game. If you don't want to do that, then why learn assembler?
