Assembly Language Problem
Discussion in 'Homework Help' started by Digit0001, Sep 24, 2010.
  1. Digit0001
    Mar 28, 2010
    89
    Hi
    Can someone tell if my code is correct?
    Write an assembly language subroutine for the HCS12 that prints out the byte in accumulator B as two hex digits decimal number. Assume there is a routine putch that print out the single ASCII char in accumulator B.
    Code ( (Unknown Language)):
    1.
    2. toDigit
    3.     andb    #$07    ;set to 3 digits
    4.     cmpb    #'1'
    5.     blo        end      ;check if lower
    6.     cmpb    #'9'
    7.     bhi        end      ;check if higher
    8.     addb    #'0'
    9.     jsr        putch     ;prints out single ASCII char
    10. end
    11.     rts
    12.
    P.S
