assembly instruction
abhimanyu143
Joined Aug 25, 2014
211
hello ,
i need help to understand how does each instruction fetch decode and execute in 8051 microcontroller
I made small project for LED blinking on proteus software
circuit :
assembly code :
Code:
       ORG     0
MainLoop:
        setb    P1.0                    ; Turn LED ON
        Acall   Delay                   ; Wait a short time
        clr     P1.0                    ; Turn LED OFF
          sjmp  MainLoop                ; Loop forever
Delay:
        mov     R1,#90                  ; Set up outer loop count
        mov     R2,#225                   ; Set up inner loop count
Delay1: djnz    R2,Delay1               ; Inner loop
        djnz    R1,Delay1               ; Outer loop
        ret
        end
I don't understand how does following instruction fetch , decode and execute ?
Code:
 MainLoop:
Acall  Delay
sjmp  MainLoop
how these instructions work with 8051 controller ?
30,621
CALL and JMP instructions work in same way on all microcontrollers (or almost all).
What part of the instruction do you not understand?
abhimanyu143
Joined Aug 25, 2014
211
I looked this link http://www.keil.com/support/man/docs/is51/is51_sjmp.htm
The SJMP instruction transfers execution to the specified address. The address is calculated by adding the signed relative offset in the second byte of the instructoin to the address of the following instruction. The range of destination addresses is from 128 before thenext instruction to 127 bytes after the next instruction.
Operation
SJMP
PC = PC + 2
PC = PC + offset
how does PC load with new address ? what is offset ?
30,621
In this particular example, offset is a signed byte, -128 to +127.
It is the distance (number of bytes) between the current instruction and the destination.
Since this instruction will occupy two bytes, that is, the opcode and the offset, the offset is adjusted by 2.
This instruction is also known as a relative branch or relative jump instruction.
abhimanyu143
Joined Aug 25, 2014
211
that's the point , I don't understand. If possible can you tell me with block diagram
basic block diagram
Operation
SJMP
PC = PC + 2
PC = PC + offset
I just want to understand basic architecture of Jump instruction (hardware ). how does PC know that PC need to jump at address ?
which component we need to add with PC to load new address ?
abhimanyu143
Joined Aug 25, 2014
211
Because you told it to JMP.
Code:
main:
  JMP here
here:
   more code
You told it JMP
You gave it the destination here
that's about code. I am trying to understand basic architecture of Jump instruction.
I want to implement small block diagram for Jump instruction
Q1 how to make architecture for jump instruction ?
hint (asking for small part for basic understanding )
Q2. what I need ?
ans. I need PC and multiplexer.I think ,I have to add extra circuitry
Q3 what is offset ?
I am not clear what is offset and how to make offset
30,621
Your processor will encounter two bytes, 80 XX
80 is the opcode for SJMP
XX is the signed byte offset
The processor will add XX to the PC and replace the result into the PC.
abhimanyu143
Joined Aug 25, 2014
211
I found this wikki page wikibooks.org/wiki/Microprocessor_Design/Program_Counter
there are diagram for jump and branch instruction. I don't understand why there are different multiplexer for jump and branch instructions. Please help me to understand that page on Program counter design.
30,621
I would ignore what you see in those diagrams. The purpose of the diagram is to show graphically what needs to be done in order to reload the PC.
What you need to do is ADD the OFFSET to the PC. That is the purpose of the box labelled ALU.
In normal instruction sequence, you want to increment the PC with the instruction byte count. So that calls for another ALU.
Then you need to choose between the two results. Is it a normal sequence or is it a JMP instruction? So you use a MUX to make the selection.
There are more ways to design a processor.
