Modifiy the following the assembley program so 1 pin of the PORTA as input=5v or 0v and other 1 pin of PORTA as output= 5v or ov
;*****Set
up the
Constants****
STATUS
equ
03h ;Address
of the
STATUS
register
TRISA
equ
85h ;Address
of the
tristate
register
for port
A
PORTA
equ
05h ;Address
of Port
A
COUNT1
equ
08h ;First
counter
for our
delay
loops
COUNT2
equ
09h ;Second
counter
for our
delay
loops
;****Set
up the
port****
bsf STATUS,5
;Switch
to Bank
movlw
00h ;Set
the Port
A pins
movwf
TRISA ;to
output.
bcf STATUS,5
;Switch
back to
Bank 0
;****Turn
the LED
on****
Start
movlw 02h ;Turn
the LED
on by
first
putting
it
movwf PORTA
;into
the w
register
and then
on the
port
;****Add
a delay
call
Delay
;****Delay
finished,
now turn
the LED
off****
movlw
00h ;Turn
the LED
off by
first
putting
it
movwf
PORTA
;into
the w
register
and then
on the
port
;****Add
another
delay****
call
Delay
;****Now
go back
to the
start of
the
program
goto
Start
;go back
to Start
and turn
LED on
again
;****Here
is our
Subroutine
Delay
Loop1 decfsz COUNT1,1
;This
second
loop
keeps
the LED
goto
Loop1
;turned
off long
enough
for us
to
decfsz
COUNT2,1
;see
it
turned
off
goto
Loop1 ;
return
;****End
of the
program****
end ;Needed
by some
compilers,
and also
;just
in case
we miss
the goto
instruction.
;*****Set
up the
Constants****
STATUS
equ
03h ;Address
of the
STATUS
register
TRISA
equ
85h ;Address
of the
tristate
register
for port
A
PORTA
equ
05h ;Address
of Port
A
COUNT1
equ
08h ;First
counter
for our
delay
loops
COUNT2
equ
09h ;Second
counter
for our
delay
loops
;****Set
up the
port****
bsf STATUS,5
;Switch
to Bank
movlw
00h ;Set
the Port
A pins
movwf
TRISA ;to
output.
bcf STATUS,5
;Switch
back to
Bank 0
;****Turn
the LED
on****
Start
movlw 02h ;Turn
the LED
on by
first
putting
it
movwf PORTA
;into
the w
register
and then
on the
port
;****Add
a delay
call
Delay
;****Delay
finished,
now turn
the LED
off****
movlw
00h ;Turn
the LED
off by
first
putting
it
movwf
PORTA
;into
the w
register
and then
on the
port
;****Add
another
delay****
call
Delay
;****Now
go back
to the
start of
the
program
goto
Start
;go back
to Start
and turn
LED on
again
;****Here
is our
Subroutine
Delay
;This
second
loop
keeps
the LED
goto
Loop1
;turned
off long
enough
for us
to
decfsz
COUNT2,1
;see
it
turned
off
goto
Loop1 ;
return
;****End
of the
program****
end ;Needed
by some
compilers,
and also
;just
in case
we miss
the goto
instruction.
