Hi there.
I'm working on a project where I try to programm a PIC16f684 with som assembly codes.
I send a digit and a data available signal from a 74c922 encoder.
It recieves a 4-bit signal on the ports RA0-RA3 and the data available on RA4
Then the pic should collect and save the digits in registers (reg0,reg1,reg2,reg3)and compare them with saved values in other registers (sreg0,sreg1,sreg2,sreg3).
If all four digits are correct the RC0 goes high.
the code works fine if only 2 digits are used no matter if it is the first or last registers are used.
I tried to test with some LEDs where the error was and I think it is burried inside the Compare part. But as a new programmer in assemby I can't figure out the error.
If anyone could look at the code it would be really appreciated.
Rich (BB code):
list p=16F684 ; list directive to define processor
#include <p16F684.inc> ; processor specific variable definitions
errorlevel -302 ; suppress message 302 from list file
errorlevel -207 ; suppress message 207 from list file
__CONFIG _CP_OFF & _CPD_OFF & _BOD_OFF & _PWRTE_ON & _WDT_OFF & _INTRC_OSC_NOCLKOUT & _MCLRE_OFF & _FCMEN_OFF & _IESO_OFF
org 0x000
;Deklarering af konstanter ;makes the registers for saved values
sreg0 equ 0x20
movlw b'1001'
movwf sreg0
sreg1 equ 0x21
movlw b'0101'
movwf sreg1
sreg2 equ 0x22
movlw b'0011'
movwf sreg2
sreg3 equ 0x23
movlw b'0001'
movwf sreg3
;Deklarering af variable ;makes registers for variable values
reg0 equ 0x27
clrf reg0
reg1 equ 0x28
clrf reg1
reg2 equ 0x29
clrf reg2
reg3 equ 0x30
clrf reg3
temp equ 0x31
clrf temp
;Initialisering ;sets RA-ports to digital. RA0-RA5 til input. All RC-ports to output
bcf STATUS,5
clrf PORTA
movlw 0x07
movwf CMCON0
bsf STATUS,5
clrf ANSEL
movlw 0x1F
movwf TRISA
movlw b'000000'
movwf TRISC
bcf STATUS,5
clrf PORTC
;sørger for at alle porte er udgange undtaget RA 3, som skal være indgang
Start ;tests if data available is high. If high goto Indlaes otherwise goto Start
bcf STATUS,5
clrf PORTC
btfsc PORTA,4
goto Indlaes
goto Start
Indlaes ;a shift register to move reg2 to reg3, reg1 to reg2, reg0 to reg1 and the new 4-bit to reg0
movf reg2,0
movwf reg3
movf reg1,0
movwf reg2
movf reg0,0
movwf reg1
movf PORTA,0
movwf reg0
goto Compare
Compare ;compares all reg registers with sreg registers
movf sreg0,0
xorwf reg0,0
movwf temp
btfsc temp,0
goto Start
btfsc temp,1
goto Start
btfsc temp,2
goto Start
btfsc temp,3
goto Start
movf sreg1,0
xorwf reg1,0
movwf temp
btfsc temp,0
goto Start
btfsc temp,1
goto Start
btfsc temp,2
goto Start
btfsc temp,3
goto Start
movf sreg2,0
xorwf reg2,0
movwf temp
btfsc temp,0
goto Start
btfsc temp,1
goto Start
btfsc temp,2
goto Start
btfsc temp,3
goto Start
movf sreg3,0
xorwf reg3,0
movwf temp
btfsc temp,0
goto Start
btfsc temp,1
goto Start
btfsc temp,2
goto Start
btfsc temp,3
goto Start
goto Afbryd ;if all four digits are correct goto Abryd
Afbryd ;sets RC0 to high. When the user press 0x0B (11 in decimal) on the keypad the code goes back to Start
bcf STATUS,5
bsf PORTC,0
movf PORTA,0
movwf temp
movlw 0x0B
xorwf temp,1
btfsc temp,0
goto Afbryd
btfsc temp,1
goto Afbryd
btfsc temp,2
goto Afbryd
btfsc temp,3
goto Afbryd
goto Start
end
