assembly code help
Discussion in 'Homework Help' started by emaney, Jun 16, 2007.
  1. emaney
    Jun 16, 2007
    The following code does this
    ;pic16f84a question
    ;A de-multiplexer has an input line, pinRB0, and four output
    ;lines, output0 to output3, which are, respectively, the pins RA0-RA3. the
    ;demultiplexer copies the digital signal appearing on the input line on to one of
    ;the four output lines. The output line is selected by a two bit
    ;selection code input on the pins RB1 and RB2.
    PLEASE LOOK AT THE CODE BECAUSE ITS NOT EXACTLY DOING WHA IT IS MENTIONED ABOVE ANYONE CAN HELP TO FIX THIS..............PLEASE
    #DEFINE PAGE0 BCF 0x03,5
    #DEFINE PAGE1 BSF 0x03,5
    PCL: EQU 0x02
    STATUS: EQU 0x03
    PORTA: EQU 0x05
    TRISA: EQU 0x05
    PORTB: EQU 0x06
    TRISB: EQU 0x06
    W: EQU 0
    F: EQU 1
    ORG 0x0
    goto MAIN
    org 5
    MAIN:
    clrf PORTA
    clrf PORTNB
    PAGE1
    movlw B'00000111'
    iorwf TRISA,F ;RA0-RA2 as input
    clrf TRISB ;Port B0-B7 as output
    PAGE0
    loop:
    ;get the output selector
    movf PORTB,w
    rrf WREG
    andlw B'00000011'
    ;convert 0-3 to bit-mask
    call table
    movwf Mask
    ;switch all zeroes to ones in mask and vice versa
    xorlw B'11111111',w
    ;read all the bits of PORTA but the selected one (leave it clear)
    andwf PORTA,w
    ;if PORTB.0 is set, set also selected output in PORTA
    btfsc PORTB,0
    xorwf Mask,w
    ;write modified value back to PORTA
    movwf PORTA
    goto loop
    table:
    addwf PCL,F
    retlw B'00000001'
    retlw B'00000010'
    retlw B'00000100'
    retlw B'00001000'
  2. n9352527
    Oct 14, 2005
    1,198
    You are setting PORTA as input and PORTB as output. It should be the other way around.
