Hi, I am trying to write a program for a timer. The operation is given as follows:
- The diodes show the number of seconds/minutes elapsed since start/restart.
- By pressing Switch2 the diodes show the number of minutes.
- By pressing Switch3 the diodes show the number of seconds.
- After 60 minutes the timer is reset.
I am pretty much a complete beginner when it comes to Assembler programming, so I feel like this is way out of my league. But I think I figured out which registers to set at least. And I also know that I need to set the program up for interrupts and initialize the stack pointer. The following is what I have so far.
.include "M32def.inc"
.def temp=R16
.org 0 jmp start
.org 2 jmp Sw2
.org 4 jmp Sw3
start:
;---PortB as out-port---
ldi temp, 0xFF
out DDRB, temp
;---Initialize for interrupts INT0 and INT1---
ldi temp, 0xC0
out GICR, temp ; set bits 6 and 7 to enable interrupts from INT0 and INT1
ldi temp, 0x0A
out MCUCR, temp ;set bits 3 and 1 to trigger interrupts when the switches are pressed down
;---other registers---
ldi temp, 0x0B
out TCCR1B, temp ; count frequency = 65.5k (0xF424)
ldi temp, 0xF4
out OCR1AH, temp
ldi temp, 0x24
out OCR1AL, temp ; interrupt every second, when the contents of the count registers
ldi temp, 0x0f ; is equal to the "output compare" registers.
out TIMSK, temp ; set bit 4 to enable Timer1 CompA match interrupt.
;---Initialize stack pointer-----
ldi temp, HIGH (RAMEND)
out sph, temp
ldi temp, LOW (RAMEND)
out spl, temp
sei ; global interrupt enable
Of course, I have neither the main program nor the two subroutines. Is what I have so far correct, though? And how should I approach writing the stuff that I'm missing?
Bit of a long question here, but hopefully someone who knows this stuff can give me a few pointers.
Thanks!
.def temp=R16
.org 0 jmp start
.org 2 jmp Sw2
.org 4 jmp Sw3
start:
ldi temp, 0xFF
out DDRB, temp
ldi temp, 0xC0
ldi temp, 0x0A
ldi temp, 0x0B
ldi temp, 0xF4
out OCR1AH, temp
ldi temp, 0x24
out sph, temp
out spl, temp
Thanks!
