asm rlc versus c shift<<
Discussion in 'Embedded Systems and Microcontrollers' started by embedtechnology, Apr 15, 2016.
  1. embedtechnology
    Dec 25, 2015
    25
    I want to rotate a variable through another variable so that D7 bit of variable 0 will enter into bit D0 position of
    variable 1 ( like ASM: rlc variable 0, rlc variable 1 ) . But in c variable0<<=1 loads 0 into D0 position of variable0
    and removes bit D7. I am using mikroc compiler.Actually I want to develop a project which is nothing but a led massage
    display,in which row scanning technology is taken into consideration. The syntax is needed for scrolling function.
    Any idea please.
  2. dannyf
    Sep 13, 2015
    2,196
    417
    Left shift variable 1.
    Set or clear variable 1 lsb based on variable 0 msb.
    Left shift variable 0.
    Fancier ways to do it also exist.
  3. NorthGuy
    Jun 28, 2014
    611
    121
    In C, you would probably define a 16-bit variable then do
    Code (C):
    1. int x;
    2. x <<= 1;
    You can get the result of the shift from the high byte of the variable. In C it is:
    Code (C):
    1. char y;
    2. y = x >> 8;
    It may look like a long shift, but most compilers will know that it only means taking the high byte.
