hi all i have a problem i have a asm code and would like it into a hex file the problem is the program i use tells me there are errors and will not make a hex file can anyone help it is for the 12f629 chip
here is the asn code
; Navlights.asm LED Lighting System
; Bruce Abbott bhabbott@paradise.net.nz
; for Microchip PIC 12C508, 12C509, 12F629 or 12F675.
; Summary of Changes
; 2005/03/15 V0.0 - Created from RXDecode.asm
; 2005/08/06 V0.1 - Two strobe lights, asyncronous flash sequence.
; 2005/12/17 V0.2 - Servo input selects Landing, Lights On, or Lights Off.
#DEFINE TIME 4 ; number of servo pulses per strobe state
#DEFINE version "0.2"
;#DEFINE __12C508 ; enable if processor not specified elsewhere
;#DEFINE __12F675 ; MPLAB users should use menu <Configure/Select Device>
;#DEFINE NO_OSCCAL ; enable if OSCCAL value was erased!
ifdef __12C508
PROCESSOR PIC12C508
INCLUDE <P12C508.inc>
__CONFIG _MCLRE_OFF&_CP_OFF&_WDT_ON&_IntRC_OSC
else
PROCESSOR PIC12F675
INCLUDE <P12F675.inc>
__CONFIG _MCLRE_OFF&_CP_OFF&_WDT_ON&_BODEN_ON&_INTRC_OSC_NOCLKOUT
endif
radix dec
errorlevel 0,-305,-302
; Bit definitions for the GPIO register and the TRIS register
; NOTE: LED is turned on when its GPIO ouput is LOW.
#DEFINE STRB1 5 ; pin 2 Strobe Light #1
#DEFINE STRB2 4 ; pin 3 Strobe Light #2
#DEFINE SERVO 3 ; pin 4 servo pulse input
#DEFINE LAND 2 ; pin 5 Landing Lights
#DEFINE LED1 1 ; pin 6 Fixed lighting (eg. Navigation Lights)
#DEFINE LED2 0 ; pin 7 More Fixed Lighting (eg. Cabin Lights)
#DEFINE TrisBits (1<<SERVO) ; servo pulse is an input
; -------------------- OPTIONS ------------------------
; no wakeup (12C508)
; weak pullups enabled
; Timer 0 source internal
; Prescaler to Timer 0, divide by 256.
ifdef __12C508
#DEFINE OptionBits B'10000111'
else
#DEFINE OptionBits B'00000111'
endif
; Macro for generating short time delays
NO_OP MACRO count
NO_OP_COUNT SET count
WHILE NO_OP_COUNT>1
goto $+1 ; 2 clocks
NO_OP_COUNT SET NO_OP_COUNT-2
ENDW
IF NO_OP_COUNT
nop ; 1 clock
ENDIF
ENDM
; Macro to create offsets for variables in RAM
ifdef __12C508
ByteAddr SET 7
else
ByteAddr SET 32 ; user RAM starts here
endif
BYTE MACRO ByteName
ByteName EQU ByteAddr
ByteAddr SET ByteAddr+1
ENDM
; RAM Variable Definitions
BYTE Flags ; various boolean flags
BYTE ServoCount ; servo pulse length. 1~255 = 0.01~2.55mS
BYTE Timer ; delay timer for strobes
BYTE Strobe1 ; strobe 1 sequencer
BYTE Strobe2 ; strobe 2 sequencer
BYTE Glitches ; number of consecutive bad servo pulses
BYTE Temp1
BYTE Temp2
; flag values
#DEFINE WATCH 0 ; Watchdog timed out
#DEFINE STROBE1 1 ; strobe 1 on
#DEFINE STROBE2 2 ; strobe 2 on
#DEFINE LANDING 3 ; Landing lights on
; Code
ORG 0
goto ColdStart
;-------------------------- version string ----------------------------------
org 8
ifdef __12C508
dt "LIGHT508"
endif
ifdef __12F629
dt "LIGHT629"
endif
ifdef __12F675
dt "LIGHT675"
endif
dt "--V"
dt version
dt "--"
ColdStart:
bcf Flags,WATCH
btfss STATUS,NOT_TO ; copy Watchdog timeout flag
bsf Flags,WATCH
; get oscillator calibration value and use it to fine-tune clock frequency.
; 12C508/9 has value in W at startup, 12F629/75 gets it from RETLW at 0x3ff.
ifdef __12C508
ifdef NO_OSCCAL
movlw 0x90 ; replace with value for your PIC!
endif
movwf OSCCAL ; set oscillator calibration
else
bsf STATUS,RP0 ; register bank 1 (12F629/75)
call 0x3ff ; get OSCCAL value
bcf STATUS, RP0 ; register bank 0
endif
; set options
ifdef __12C508
movlw OptionBits
option
else
movlw OptionBits
movwf OPTION_REG
bcf STATUS,RP0 ; register bank 0
endif
; initialise I/O registers
ifdef __12C508
movlw 0
movwf GPIO ; all outputs on
movlw TrisBits
TRIS GPIO ; set I/O pin directions
else
clrf GPIO ; all outputs low
movlw TrisBits
movwf TRISIO ; set I/O pin directions
ifdef ANSEL
clrf ANSEL ; disable analog inputs (12F675)
endif
ifdef CMCON
movlw b'00000111'
movwf CMCON ; Comparator off
endif
endif
; CPU specific stuff done, now we can start the main program!
goto Main
SeqStrobe1:
ifdef PCLATH
clrf PCLATH
endif
movf Strobe1,w
addwf PCL
retlw b'00000001'
retlw b'00000000'
retlw b'00000001'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'10000000'
SeqStrobe2:
ifdef PCLATH
clrf PCLATH
endif
movf Strobe2,w
addwf PCL
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000001'
retlw b'00000000'
retlw b'00000001'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'10000000'
; Millisecond Delay Timer
; Input: W = number of milliseconds to wait (max 256mS)
dx1k: movwf Temp1
_dx1k1: movlw (1000-5)/5
movwf Temp2
_dx1k2: clrwdt ; avoid watchdog timeout
nop
decfsz Temp2 ; wait 1mS
goto _dx1k2
decfsz Temp1
goto _dx1k1
retlw 0
; Main
Main: btfsc Flags,WATCH ; did the watchdog timeout ?
goto MainLoop ; oops! try to keep going ...
clrf Flags ; clear all flags
movlw 250 ; wait 500mS for power to stabilise
call dx1k
movlw 250
call dx1k
movlw TIME
movwf Timer
clrf Strobe1
clrf Strobe2
clrf Glitches
MainLoop: clrf TMR0 ; start timer
WaitLow: clrwdt ; avoid watchdog timeout
btfsc TMR0,7 ; timer reached 33mS ?
goto NoSignal
btfsc GPIO,SERVO ; wait for no servo pulse
goto WaitLow
waitpulse: clrwdt ; avoid watchdog timeout
goto NoSignal
btfss GPIO,SERVO ; wait for start of servo pulse
goto waitpulse
clrf ServoCount
measure: clrwdt ;1
incf ServoCount ;2 count = pulse width (* 10uS)
skpnz ;3 > 2.55mS ?
goto BadPulse ;4 Yes, error
NO_OP 3 ;5~7
btfsc GPIO,SERVO ;8 servo pulse finished ?
goto measure ;9,10 no, continue measuring
movlw 70
subwf ServoCount,w ; less than 0.7mS ?
skpc
goto BadPulse ; yes, bad pulse
bcf Flags,LANDING ; assume landing lights are off
movlw 130
subwf ServoCount,w ; less than 1.3mS ?
skpc
bsf Flags,LANDING ; yes, landing lights on
movlw 170
subwf ServoCount,w ; less than 1.7mS ?
skpc
goto power_on ; yes, power on
power_off movlw 1<<STRB1|1<<STRB2|1<<LAND|1<<LED1|1<<LED2
movwf GPIO ; All lights OFF
goto GoodPulse
power_on: bcf GPIO,LED1 ; fixed lights ON
bcf GPIO,LED2
landing_lights: btfss Flags,LANDING
bsf GPIO,LAND ; Landing lights OFF
btfsc Flags,LANDING
bcf GPIO,LAND ; Landing lights ON
strobes: decfsz Timer ; time for next strobe change?
goto GoodPulse ; no, done
movlw TIME
movwf Timer ; restart timer
call SeqStrobe1 ; get Strobe 1 state
movwf Temp1
incf Strobe1 ; next state
btfsc Temp1,7 ; end of sequence ?
clrf Strobe1 ; restart sequence
bcf Flags,STROBE1
btfsc Temp1,0 ; strobe 1 to be on ?
bsf Flags,STROBE1
call SeqStrobe2 ; get Strobe2 state
movwf Temp1
incf Strobe2 ; next state
clrf Strobe2 ; restart sequence
bcf Flags,STROBE2
btfsc Temp1,0 ; strobe 2 to be on ?
bsf Flags,STROBE2
btfss Flags,STROBE1
bsf GPIO,STRB1 ; flash strobe 1
btfsc Flags,STROBE1
bcf GPIO,STRB1
btfss Flags,STROBE2
bsf GPIO,STRB2 ; flash strobe 2
btfsc Flags,STROBE2
bcf GPIO,STRB2
GoodPulse: tstf Glitches
skpnz
goto done
decf Glitches ; another good pulse received
goto done
BadPulse: incf Glitches ; another bad pulse!
movlw 10
subwf Glitches,w
skpc ; too many bad pulses?
goto done
decf Glitches
NoSignal: movlw 1<<STRB1|1<<STRB2|1<<LAND|1<<LED1|1<<LED2
movwf GPIO ; turn off all outputs
done: goto MainLoop
;---------- Oscillator Calibration Subroutine (12F629/75 only) --------------
ifdef __12F675
org 0x3ff
retlw 0x90 ; replace with oscal value for your PIC!
endif
END
ifdef __12C508
PROCESSOR PIC12C508
else
PROCESSOR PIC12F675
endif
radix dec
ifdef __12C508
else
endif
NO_OP MACRO count
WHILE NO_OP_COUNT>1
goto $+1 ; 2 clocks
ENDW
IF NO_OP_COUNT
nop ; 1 clock
ENDIF
ENDM
ifdef __12C508
ByteAddr SET 7
else
endif
BYTE MACRO ByteName
ENDM
BYTE Temp1
BYTE Temp2
; flag values
; Code
ORG 0
goto ColdStart
org 8
ifdef __12C508
dt "LIGHT508"
endif
ifdef __12F629
dt "LIGHT629"
endif
ifdef __12F675
dt "LIGHT675"
endif
dt "--V"
dt version
dt "--"
ColdStart:
bcf Flags,WATCH
bsf Flags,WATCH
ifdef __12C508
ifdef NO_OSCCAL
endif
else
endif
; set options
ifdef __12C508
movlw OptionBits
option
else
movlw OptionBits
movwf OPTION_REG
endif
ifdef __12C508
movlw 0
movlw TrisBits
else
movlw TrisBits
ifdef ANSEL
endif
ifdef CMCON
movlw b'00000111'
endif
endif
goto Main
SeqStrobe1:
ifdef PCLATH
clrf PCLATH
endif
movf Strobe1,w
addwf PCL
retlw b'00000001'
retlw b'00000000'
retlw b'00000001'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'10000000'
SeqStrobe2:
ifdef PCLATH
clrf PCLATH
endif
movf Strobe2,w
addwf PCL
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000001'
retlw b'00000000'
retlw b'00000001'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'10000000'
dx1k: movwf Temp1
movwf Temp2
nop
goto _dx1k2
decfsz Temp1
goto _dx1k1
retlw 0
; Main
call dx1k
movlw 250
call dx1k
movlw TIME
movwf Timer
clrf Strobe1
clrf Strobe2
clrf Glitches
goto NoSignal
goto WaitLow
goto NoSignal
goto waitpulse
clrf ServoCount
measure: clrwdt ;1
skpnz ;3 > 2.55mS ?
NO_OP 3 ;5~7
movlw 70
skpc
movlw 130
skpc
movlw 170
skpc
goto GoodPulse
bcf GPIO,LED2
btfsc Flags,LANDING
movlw TIME
movwf Temp1
bcf Flags,STROBE1
bsf Flags,STROBE1
movwf Temp1
bcf Flags,STROBE2
bsf Flags,STROBE2
btfss Flags,STROBE1
btfsc Flags,STROBE1
bcf GPIO,STRB1
btfss Flags,STROBE2
btfsc Flags,STROBE2
bcf GPIO,STRB2
skpnz
goto done
goto done
movlw 10
subwf Glitches,w
goto done
decf Glitches
done: goto MainLoop
ifdef __12F675
org 0x3ff
endif
END
