ASM Chart / Datapath Circuit
Discussion in 'Homework Help' started by jegues, Dec 8, 2010.
  1. jegues
    Sep 13, 2010
    See figure(s) attached for problem statement as well as my attempt.
    Can someone please check my ASM Chart to see if I've done it correctly?
    R, A and B and C are indicated the top of the page and s is my start signal.
    In my first state R is initialized to 0 and the counter C is loaded with all 1's.
    It keeps checking for a start signal and continues to load A and B until it recieves one.
    State 2 was the state I was moreso confused about.
    What should I have contained in my Moore-Diagram box for this state? Also, what about the Mealy-Output circle associated with S2?
    It continues in this state until C=0 then it travels to "Done", state 3.
    Once in state 3 constantly checks to make sure that the start signal has returned to 0 before returning back to the original state.
    What do you guys think? Is this thing working? Are there certain things I need to change?
    Once I get the chart down, I'll start working on the datapath circuitry.
    Thanks again!
