Asking for 5-7Amp connector recommendations
Discussion in 'General Electronics Chat' started by Wendy, May 29, 2013.
  1. Wendy
    Thread Starter Moderator
    Mar 24, 2008
    20,772
    2,540
    I'm not sure a 3.5mm barrel power connector is rated for this kind of load. I could use Molex, but they tend to be ugly and cumbersome.
    Recommendations?
  2. mcgyvr
    Oct 15, 2009
    4,795
    979
    number of poles?
    board-board?
    wire-board?
    panel mount?
    connectorized or wire clamp?
    touch safe?
    ,etc...
  3. MrChips
    Oct 2, 2009
    12,656
    3,461
    I had the same problem not too long ago. I replaced the 3.5mm barrel connector with banana jacks and 16AWG cabling.
    This was for a permanent 19" rack mount equipment so banana jacks work well in this situation.
    btw, the 6A load was split and distributed to a number of mcu boards via IDC ribbon cable and connectors. One split was taking 2A, I think, and the ribbon cable and connector got discolored from heat stress.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Thanks, I'm going to try to find a socket solution if I can. Definitely a polarized one.
    Come to think of it, I have seen barrels used on laptops, which pulls current in that range. I'll look around for some spec sheets.
    I have this delusion of making a 100W class D audio amp for a PA/sound system (mono). I've already bought a 100W speaker in a enclosure, 6-8Ω, and I've picked up a 24VDC 5A power supply for under $10. Now to figure out how to get CMOS to run on 24VDC with minimum parts count. I have a few ideas on the subject.
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    Wendy likes this.
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
  7. MrChips
    Oct 2, 2009
    12,656
    3,461
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    Radio Shack used to sell the Jones Connectors. I was kinda hoping to find them again, knowing the name is more than half the battle. It was during the CB craze years.
  9. Georacer
    Nov 25, 2009
    5,151
    1,266
  10. GopherT
    Nov 23, 2012
    6,340
    4,094
    The brushless motors used in R/C airplanes are pulling 20 amps and more from lithium polymer batteries. They use a high-capacity barrel connector with 10 to 12 gauge wire.
    Check out your local R/C hobby store.
  11. Gary_P
    Apr 4, 2013
    7
    You might give the XLR connector a thought. The Neutrik XLR contacts are rated for 16A each and don't cost much.
    The 3 contacts would give you the capability to have + - and Ground separate for ground loop control.
    XLR's look nice also if that matters.
