Ask a easy question about controling system, the problem is following
Discussion in 'Homework Help' started by Liyou, Apr 11, 2015.
  1. Liyou
    Apr 11, 2015
    For an unit-feedback system with the open-loop ransfer function G(s)=K/(s(0.1s+1)),
    (1)For K=1,determine the damping ration、rise time、delay time and setting time
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The name of this section is Homework Help, not Homework Done For You. In order to get help you need to tell us what you know and show us your best efforts to arrive at a solution. There are numerous online examples showing how to do these things. There is also presumably your textbook, your class notes, and your instructor during his office hours.
    Can you for example derive the closed loop transfer function?
    Can you define those things you mentioned? If you can define them you should be able to calculate them.
