ASCII symbol
Discussion in 'General Electronics Chat' started by nanobyte, Sep 25, 2006.
  1. nanobyte
    Thread Starter Senior Member
    May 26, 2004
    118
    Does anybody out there know the correct ASCII code for the degree sign (like for temperature or angles). I have search all of the internet and cannot find it. There are plenty of sites out there that offer ASCII codes for the degree symbol, but thus far I haven't found a single one that is right. I'll take any number system (octal, hex, or decimal). I'm trying to displaying the temperature on a LCD.
  2. pebe
    Oct 11, 2004
    628
    It's extended ASCII code 167 dec. That prints correctly to screen in 'Word'. But you cannot send it, as is, to an LCD display to print out.
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    143
    In light of pebe's comments.
    Is there scope for creating your own degree symbol as part of a user-dfined chararcter map?
    Dave
  4. sci-3d
    Aug 22, 2006
    51
    Assembly or C. I also work the same kind as you but I use C.
    I use ads7841 12 bit ADC convert analog output from Range Sensor.
    The value from Ads7841 is 12 bit BCD (0-4096) which can be easy displayed on LCD
    by using integer to ASCII convertion routine, see
    http://mcu-programming.blogspot.com/2006/09/adc-interfacing.html
  5. n9352527
    Oct 14, 2005
    1,198
    If you are using a Hitachi compatible LCD controller (such as HD44780), the degree symbol is mapped at 11011111 (0xDF). If not, then the easiest way to find out the code is from the datasheet. If no datasheet available, then you could try sending all possible combinations one by one and see what comes up. For example, with 8-bit parallel interface, you could send from 0x00 to 0xFF, keeping in mind that some of the codes are reserved and might do something else.
