asap help please
cassity69
Joined Dec 18, 2013
37
right cut a long story short in a group of two i have been involved with the making of a project which is 50/50 split
ive completed my half and my friend has aswell but my assesor has asked me for some extra information from my partners half which i am not that clued up on hes at work and i said ill try my best to do it
basically hes created a programme for a half effect sensor using a pic18f4520 i have the programme on my usb now but cant really make a clear picture of it
any advice how i could read from this ?
any help from where i could start would be great
the hall effect sensor has been soldered next to a stepper motor and when the stepper motor rotates the hall effect sensor counts how many times the wheel rotates
this is to measure the rpm
that is all i know lol
i have the full code if anyone wants me to inbox it to them
MaxHeadRoom
Joined Jul 18, 2013
28,702
If you have the code listing, what language is it programmed in?
It could be in Assembly or C as the most common methods.
What extra info is the assessor need?
For that type of application i usually use the input interrupt pin.
Max.
cassity69
Joined Dec 18, 2013
37
ive just messged you
he just needs a flow diagram for the code
ive started it
ive done
start
initialise pic
setup timers
setup interupts
then im completely lost
cassity69
Joined Dec 18, 2013
37
Rich (BB code):
#include <p18f4520.h> // header files of PIC18F4520
#include <delays.h> // include delays
#include <portb.h> // Header files required for port B interrupts
#include <usart.h>
#include <stdlib.h>
#include <stdio.h>
#include <float.h>
#pragma config WDT = OFF
#pragma config LVP = OFF
#pragma config DEBUG = ON
#pragma config OSC = HS
/*Declare functions*/
void EnableInterrupts (void);
void HIGH_ISR (void);
void LOW_ISR (void);
//Globals
unsigned int TMR1overflowCnt = 0;
unsigned int TMR1FinalOverflowCnt = 0;
unsigned int TMR1FinalCnt = 0;
char CountFinished = 0;
// main function
void main (void)
long ClockCount = 0;
long SignalPeriod = 0;
long TwoToPowerSixteen = 65536;
long OSCperiod = 0.00000005;
TRISA = 0x00; //Set port A as output
LATA=0; //Initialize Port A.
ADCON1 = 0b00001111; //All ADC disabled
TRISD = 0x00; //Set port D as
TRISB = 0xff;
    OpenUSART(USART_TX_INT_OFF & USART_RX_INT_OFF & USART_ASYNCH_MODE & USART_EIGHT_BIT & USART_CONT_RX & USART_BRGH_HIGH, 64);
INTCON2bits.RBPU = 1;	//Disable port B pullups
ADCON1 = 0X0f;			//Disable ADC
EnableInterrupts();				//Enable appropriate interrupts
while(1)
		if (CountFinished == 1)
			ClockCount = (TMR1FinalOverflowCnt*TwoToPowerSixteen) + TMR1FinalCnt;
			SignalPeriod = ClockCount*OSCperiod;
			CountFinished = 0;
		Nop();
void HIGH_ISR (void)	// High priority interrupt service routine
//int ControlNob0,ControlNob1,ControlNob2;
	if(	PIR1bits.TMR1IF == 1)
		TMR1overflowCnt++;
		PIR1bits.TMR1IF = 0;
	if(INTCONbits.INT0IF == 1)
		TMR1L = 0;
		TMR1H = 0;
		INTCONbits.INT0IF = 0;
	if(INTCON3bits.INT1IF == 1)
		TMR1FinalOverflowCnt = TMR1overflowCnt;
		TMR1FinalCnt = TMR1H<<8 + TMR1L;
		CountFinished = 1;
		INTCON3bits.INT1IF = 0;
	INTCONbits.GIE = 1;		//Enable global interrupts
void LOW_ISR (void)		// High priority interrupt service routine
	Nop();
#pragma code low_vetor=0x18			//Instruct complier to serve low priority interrupts as memory location 0x18
void interrupt_at_low_vector(void)
	_asm
		GOTO LOW_ISR					//Jump to low ISR
	_endasm
#pragma code // Return to default code section
#pragma code high_vetor=0x08			//Instruct complier to serve high priority interrupts as memory location 0x08
void interrupt_at_high_vector(void)
	_asm
		GOTO HIGH_ISR					//Jump to high ISR
	_endasm
//*********************Enable interrupts**********************************
	//External interupt setup
	//Flags
	INTCONbits.INT0IF 	= 0; //Set INT0 flag to 0
	//Set prioity
	//Note INT0 is always high priority
	INTCON3bits.INT1P = 1;
	INTCON3bits.INT2P = 1;
	//Set INT0,1,2 to interupt on rising edge.  Can be made to be
	INTCON2bits.INTEDG0 = 1;	//1 interupts on riseing edge
	INTCON2bits.INTEDG1 = 0;
	//Enable interupts
	INTCONbits.INT0IE 	= 1;	//Enable INT0
	//Enable priority interupts
	INTCONbits.GIEL = 1;	//Enable low priority interrupts
	INTCONbits.GIEH = 1;	//Enable high priority interrupts
	RCONbits.IPEN 	= 1;	//Enable priority’s for interrupts make all high
	T1CONbits.RD16 = 1;
	T1CONbits.T1RUN = 1;
	T1CONbits.T1CKPS1 = 0;
	T1CONbits.T1CKPS0 = 0;
	T1CONbits.TMR1CS = 0;
	T1CONbits.T1SYNC = 0;
	T1CONbits.T1OSCEN =1;
	T1CONbits.TMR1ON = 1;
//Set interupts
	IPR1bits.TMR1IP = 1;
	PIE1bits.TMR1IE=1;
