1. namratha_r
    Jan 27, 2015
    23
    Code (Text):
    1. unsigned int array[] ={1,2,3,4,5,6,7,8,9,10}
    2. .
    3. .
    4. .
    5. for(i=0; i<10; i+)
    6. {
    7.      led = 1                      // led on
    8.      delay(1);                 / /array num 1
    9.      led = 0                    // led off
    10.      delay(2);               // array num 2
    11. }
    have struck in this... actually i want to control led on/off by giving delays initialized in array. It should take alternately i mean 1 for ON , 2 for OFF again 3 for ON ...... so how to minimize the code by using conditions have struck ... please help me out..
  2. MrChips
    Oct 2, 2009
    12,636
    3,454
    Before writing code, define what you want to do.
    Draw a flow chart or use pseudo-code.
    Make sure it makes sense.
  3. Art
    Distinguished Member
    Sep 10, 2007
    797
    61
    The intention is roughly there.
    Code (Text):
    1.
    2.
    3. int i
    4. unsigned int array[] ={1,2,3,4,5,6,7,8,9,10}
    5.
    6.
    7. for(i=0; i<9; i+)
    8. {
    9.      led = 1                      // led on
    10.      delay(array[i]);                 / /array num 1
    11.      led = 0                    // led off
    12.      delay(array[i]);               // array num 2
    13. }
    14.
    15.
  4. Art
    Sep 10, 2007
    797
    61
    Ok I get it, your array wasn’t long enough for 10 flashes for two values for each on/off cycle
    This assumes led is a bit variable and cycles from 1 to 0 and back again as you increment it.
    Code (Text):
    1.
    2. int i
    3. unsigned int array[] ={1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20}
    4.
    5. index = 0;
    6. for(i=0; i<19; i+) {
    7.      led = led + 1;                     // led on
    8.      delay(array[i]);                 //array num 1
    9. }
    10.
    11.
  5. MrChips
    Oct 2, 2009
    12,636
    3,454
    You get it. I don't.
  6. namratha_r
    Jan 27, 2015
    23
    thanks ... I got it
