An alphabetic suffix can mean other things as well:some applications benefit from low or lower gain...
The gain is a complex parameter, among other things, largely depends on the current.
AFAICR: The favourites for a little bit more current are; BC327/337 in Europe and 2SA1015/2SC1815 in Asia.If I recall correctly, the 2N4403 is a switching transistor with a fairly high current capability. If you replaced them with a 2N3904 type, you might have trouble. It depends entirely on the circuit which you have not revealed to us.
It looks like the original question disappeared. I can only chalk it up to lots of noisy website construction work going on where we can't see it. Things get misplaced, or maybe the TS deleted his post. I'm not the person to ask because I'm not on the construction crew.@#12
What the hell happened to this dangling participle? What did this line of transistor talk get ripped off of the original thread? And post #9 just showed up as a new post today - even though it was posted on the 27th of June.
