Are these the same??
Discussion in 'Homework Help' started by darkknight, Oct 7, 2009.
  1. darkknight
    Thread Starter Active Member
    Oct 7, 2009
    41
    i have to calculate the equivalent resistor and i redrew the drawing to make it simpler to calculate, are these the same?
    thanks in advance
  2. studiot
    Nov 9, 2007
    5,005
    515
    They are not the same, which is the original?
  3. darkknight
    Oct 7, 2009
    41
    the one in white, i made the yellow one
  4. studiot
    Nov 9, 2007
    5,005
    515
    You are nearly there.
    In a similar style to your yellow one I make it as follows.
      File size:
      11.7 KB
      15
  5. darkknight
    Oct 7, 2009
    41
    i was so close... thanks once again
  6. jpanhalt
    Jan 18, 2008
    5,699
    909
    Please don't remove the original problem. It makes the whole thread worthless to others.
    John
