Are these the right frequencies for this RLC circuit?
Discussion in 'Homework Help' started by lll, Apr 26, 2012.
  1. lll
    Mar 7, 2012
    21
    The circuit is attached (disregard answer choices).
    I have doubts about whether I found the right frequencies because they result in weird looking roots for the characteristic equation. So I just want to check that I have them right.
    (alpha) = 2500000
    (omega0) = 10000
    Are these right?
      File size:
      26.2 KB
      18
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    You don't need the CE because you are only concerned with the instant the switch turns on. At that point the rate of change of current is simply Vdc/L A/sec.
    lll likes this.
  3. lll
    Mar 7, 2012
    21
    Thanks, that one was giving me a hard time. I didn't realize that the initial inductor voltage was the same as the source voltage, but since the initial current through resistor is 0, and the initial cap voltage is 0, I guess it is.
