Are these burns on the board and how to remove them
Discussion in 'General Electronics Chat' started by capacapa, Aug 27, 2013.
  1. capacapa
    Mar 31, 2012
    17
    These black spots look like burns, aren't they? is it possible to remove them or fix this board ? is it safe to use alcohol to clean this, I also have arctic cleaner, not sure if it is also effective with this kind.
  2. #12
    Nov 30, 2010
    16,705
    7,358
    There's only one way to find out, and it's the same way you would begin to repair the board..scrape the black coating off and see if the copper underneath is damaged.
    capacapa likes this.
  3. GopherT
    Nov 23, 2012
    6,339
    4,084
    I don't see anything burnt. Where are your concerning areas?
  4. #12
    Nov 30, 2010
    16,705
    7,358
    Along the lower connector edge of the middle board.
  5. capacapa
    Mar 31, 2012
    17
    yes like #12 said, in the middle board the one in the middle of the picture, near pins 23, and 12,13 and little at the end.
    I'm beginner, so please bear with me.
    What's the best tool to use to scrape the black spots without causing damage? is there a suitable cleaner to try before attempting to scrape?
  6. #12
    Nov 30, 2010
    16,705
    7,358
    If a solvent will take it off, it's not burnt. (I don't know of anything that will dissolve carbon.)
    I use my pocket knife.
  7. capacapa
    Mar 31, 2012
    17
    :) I'll try to use a screw driver then and see. thanks for the helpful posts
  8. LDC3
    Apr 27, 2013
    920
    160
    The one in the middle looks like paint to me. I think the others are too.
    wayneh likes this.
  9. Gdrumm
    Distinguished Member
    Aug 29, 2008
    684
    36
    I've used a small brass bristle brush to clean boards, just don't be too aggressive.
    Isopropal Alcohol works well too, with an old tooth brush.
    (Wear safety glasses).
    The bottom left of the board looks like a blown SMD to me, and some of the other debris looks like acid residue. (my opinion).
    Nice photo, how did you get it so clear?
    Is there a specific problem being caused by the board?
    HTH,
    GAry
  10. strantor
    Oct 3, 2010
    4,302
    1,989
    They sell fiberglass abrasive pens for this purpose. you can get them at radioshack. I don't like them or use them much, just informing that they exist.
  11. #12
    Nov 30, 2010
    16,705
    7,358
    I dunno...I blew this pic up on my 24" LCD and it looks like paint at that size.
    BE CAREFUL with that screwdriver! It doesn't have a sharpened edge!
  12. mcgyvr
    Oct 15, 2009
    4,793
    976
    Not burns.. Paint to possibly indicate a quality control check or similar function.
    capacapa and shortbus like this.
  13. shortbus
    Sep 30, 2009
    4,098
    1,697
    +1 to what mcgyvr said. They used that, a paint marker, in a certain place after each quality check, where I worked.
  14. GopherT
    Nov 23, 2012
    6,339
    4,084
    This looks like a 30year old game console (Yamaha sound chip and "joy stick" on the PCB). What is it? A PacMan or a home console?
    EDIT:
    My error, that is a Yamaha video display processor and you have an MSX2 computer!
  15. capacapa
    Mar 31, 2012
    17
    Yes, it is MSX 2+ HB-F1XD, the problem is no video out or RF but the computer works fine. The middle one is the encoder board.
    I confirm this is paint turned out, I touched it a little bit with screw driver and immediately part of the black spot was removed, then I used arctic grease remover and an ear pick, and I was able to remove all the black spots but tiny bits on some pins which is probably wasn't the problem.
    I suspect now the caps above this board. yesterday, I found a service manual for this computer online, so going to test the pins in/out.
    This is using dslr camera, Canon EOS kiss x5. original photo was more clear, 4k in resolution, but I think tinypic resized it down.
    Thanks everyone for the help
