Are there any key fob transmitter units, or similar...
Discussion in 'General Electronics Chat' started by Glitchmobile, May 18, 2010.
  1. Glitchmobile
    May 8, 2010
    10
    Interested in retrofitting a compact remote control onto a golf buggy,
    to control at least two functions, forward motion and steering. Ready
    made R/C, that is available for the model airplane hobby would work
    well, however the transmitters are too cumbersome.
    Are there any key fob transmitter units, or similar, that could be used with a
    typical R/C hobby receiver/ servo set?
  2. retched
    Dec 5, 2009
    5,201
    313
    This uses a fob to activate relays. You could easily use that rather than standard steering, use skid steer.
    a 4 button fob, for forward, reverse, left forward only and right forward only.
    The 4 relays would run 2 motors. 1 motor connects to the right 2 wheels, and 1 motor to the left 2.
    http://rentron.com/QRELAY.htm
    and
    http://www.rentron.com/Linx/HHLR.htm
    Now you just need motors, wheels and a battery. (and a frame for holding the golf bag)
    May think of using tank treads. ;)
  3. Glitchmobile
    May 8, 2010
    10
    Thanks Retched, for the links. I came across those already. This could work,
    as the buggy I have, has a fixed axel while the drive mechanism is
    unidirectional, so a three function remote could suffice.
    If only the remotes of hobby planes, etc. were more compact...
  4. retched
    Dec 5, 2009
    5,201
    313
    I would buy a $10 remote controlled toy, and use the servos in it.
    You can easily adapt them into motors and larger servos. You just need the crystals.
